Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
Djx700 Headphone (cue) Problem. Please help.
My djx700 plays the music what i'm supposed to hear through the headphone over the master on a low volume :s. And i can't figure out why. I have it set on cue, not on master. Really strange, Please help.
Thnx
    President:
  • 1,137 Answers
Have a look at page 4 of your manual under the Monitor section, mode switch. Manual is here:http://www.behringer.de/EN/downloads/pdf/DJX700_P0165_M_EN.pdf The mode switch may be faulty or the mix control may be faulty.
Posted on Feb 03, 2010
Im not getting anything from my djx700 master output, getting sound from booth output. what could this be
The first thing I would look at is the kill switches on each side, make sure these are not pressed. Also make sure the master fader is up. I would disconnect anything that may be plugged into the effects loop send and return. Make sure the main outs are plugged in correctly, the main master outs should go to a power amp, this unit appears to be a unpowered unit. Make sure you are using the proper cables to avoid damage, lookup and understand the difference in speaker cords and instrument cords and place them properly. Also make sure the "assign A" and "assign B" are positioned correctly. Hope this helps but, if you give me a little info on how you are using this unit, I could help you further, please.
Mar 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
Frustration coming from djx700 mixer left Chanel need help :( on booth and master ??
the faders were actually fails functioning it well, it must be replace a new one!im a audio technician of BEHRINGER!
Aug 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I just purchased the behringer djx 700, and the channel 2,3,4 are all distorted when i play music. Even when i listen to it through headphones you can still hear the heavy distortion. What can i do to...
You are probably overdriving the inputs. You haven't told us the source of the inputs and we can't guess where they may come from. You need to read the manual and make sure your source outputs are within range of what this unit requires.
Jul 17, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
It hs no instument lighting,Chanell level indicators and master level indicator
is there power to it? does sound come out of it? if not it could be fried or about to fry. Behringer makes low end products, which tend to break fast. if you dont have any sound or lights chances are its unfixable
May 25, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
If the master output lights go above green (into yellow) the sound becomes slightly distorted even at low speaker levels. i have cleaned the output jacks but it is still distorted
Does the distortion ALSO appear when you listen with headphones? If not, the problem may be downstream. The driver for the mute control line to the mute transistors may have a problem. Make sure the mute is off.
Nov 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Monitor Cue problem
If you don't have the manual it is here:http://www.behringer.de/EN/downloads/pdf/DJX700_P0165_M_EN.pdf Have a look at page 4 under Monitor, mode switch and mix control. You might be having problems with them.
Feb 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Headphone output distorted on one side. Replacement jack?
studiospares (in london) or radioshack in USA, unscrew and get busy with a soldering iron, its not too hard, only 4 cables.
Jan 22, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
My behringer djx700 5 channel pro dj seems to have a feedback problem even when nothing's plugged in to it cant figure it out.
It doesn't seem like a typical "feedback" problem, as feeback is produced by over modulation between the amplifier and the source - usually a pickup or microphone. It may be your cables to your amplifier are bad, or the actual line out jack(s) may have gone bad. If it is more of a humming sound rather than feedback, that is most likely your issue. If you have additional patch cables, switch out the existing ones, and see if that ends it. If not, it is possibly the jack(s).
You have a headphone jack on the Behringer, though you did not say if the problem arises through the headphones or an external amplifier. If you get the noise in the headphones, when no patch cords or a mic is attached, then the problem you should look at is your headphones or the headphone jack. You can narrow the problem down by using an external ampifier and see if you still have the "feedback" sound. if not, it's in the headphones or headphone jack.
Please try and provide more information for this question if we are unable to track the problem with these suggestions. As we do try very hard to center in on customer's problems, we do ask to provide as much information as possible, so that we can facilitate your resonse more effeciently.
Thank you for using FixYa.
Dec 31, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
502 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
