Question about Yamaha DVD-S540 DVD Player
DVD S540-needs password and screen scrolls
I inadvertantly selected the incorrect TV on the setup. Now the screen is scrolling so quickly I cannot make out individual words. Also it is now asking for a password (which there isn't one).
    President:
  • 4,402 Answers
Open Disc Drawer
Press 99990
Close Disc Drawer
or
Open Disc Drawer
Press 99990 and then press enter/ok button (!)
Tray was closed independently by itself
and that's it. Enjoy!
Posted on Feb 19, 2008
How to open mms
IF you use cingular you can use these settings. However, if you use a different service provider you will need to change the server name depending on the information that your service provider gives you.
  • From the standby screen, press Menu.
  • Scroll to and select Messaging.
  • Press Menu.
  • Scroll to and select Inbox Setup.
  • Select MMS Message Setup.
  • Scroll to and select Server Info.
  • Scroll to and select Cingular MMS.
  • With "Cingular MMS" highlighted, press Menu.
  • Scroll to and select Edit.
  • Validate the following parameters:
  • May 03, 2011 | Motorola Mobility RAZR V3i Cellular Phone
    Cannot record on Sansui VRDVD4005
    Usually this would signal a bad disc, but if the discs have been known to be good, then your lens may be failing.
    May 14, 2009 | Televison & Video
    FINALIZING DVD+R DUBBED FROM VHS TAPES
    The manual gives you incorrect info.
    To FINALIZE disk:
    1. Press [HOME] button;
    2. select [SETUP].
    3. Scroll down to DVD ICON and SELECT
    4. Select [FINALIZE]
    Perfect Answer provided by "petoNOVY" - THIS ANSWER ALSO APPLIES TO ZENITH XBR616 - I struggled for 2 years to find it!!! THANKS!!!
    Dec 17, 2008 | Zenith XBR716
    Parental password control inadvertently activated.
    Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
    Nov 11, 2008 | RCA Televison & Video
    Piva ptv1502 screen keeps cutting off while playing can you fix problem?
    If it's a V-Chip, Parental Control issue, here's the solution. Make sure RF coaxial cable is connected to TV. Press "V-Chip Menu" on the remote. On Password, press "Enter" on the remote. In Password, enter 666666, then press "Enter". Scroll down to "Modify-PW" by using CH+ or CH- key, then press "Enter". Enter 000000, then press "Enter". Select" V-Chip Menu" to exit V-Chip. Select V-Chip Menu again. On "Password", press "Enter" key on remote control. Enter 000000 in "Password", then press "Enter". Scroll down to "V-Chip", press "Enter". TV should display a list of all TV ratings. Use CH+ or CH-, scroll to TV-Y. Then press "Enter" key on remote. Be sure that all ratings are set to "On". Repeat the steps above and set all ratings to "On". Then select "Exit", press "Enter". Press V-Chip Menu" to close on-screen menu.
    Oct 30, 2008 | Televison & Video
    Cannot send or receive pics
    Here are the MMS settings you will need to setup and/or verify:
    From the standby screen, press the Menu Key.
    Scroll to "Settings," press Select.
    Scroll to "WebAccess," press Select.
    Scroll to "Web Sessions," press Select.
    Scroll to "Cingular MMS" press Menu.
    Scroll to "Edit," press Select.
    Homepage: http://mmsc.cingular.com
    Service Type 1: HTTP
    Gateway IP: 66.209.11.32
    Port 1: 9201
    Domain 1: leave blank
    Service Type 2: WAP
    Gateway IP 2: 0.0.0.0
    Port 2: 0
    Domain 2: leave blank
    DNS 1: 0.0.0.0
    DNS 2: 0.0.0.0
    Time out: 5 minutes
    CSD no 1: leave blank
    Username: 1: leave blank
    Password 1: leave blank
    Speed (Bps) 9600
    Line Type 1: ISDN
    CSD no 2: leave blank
    User Name 2: leave blank
    Password 2 leave blank
    Speed (Bps) 2: 9600
    Line Type 2: ISDN
    GPRS APN: wap.cingular
    User Name: WAP@CINGULARGPRS.COM
    Password: CINGULAR1
    Press Done.
    Press Exit.
    Press Back
    Press Back.
    Scroll to "Messaging," press Select.
    Press the Menu key.
    Scroll to "Inbox Setup," press Select.
    Scroll to "MMS Message Setup," press Change.
    Scroll to "Server Info," press Change.
    Scroll to "MMS", press Menu key.
    Scroll to and select "Edit".
    Validate the following settings:
    Service Name: MMS
    Server Name: http://mmsc.cingular.com
    Web Session Name: MMS
    Dec 17, 2007 | Motorola Mobility RAZR V3
    MMS retreival
    Mobile phones take and display pictures in a wide variety of resolutions and file formats. Many phones can't display some of these pictures from different models because their display resolution is not compatible.
    Do you have this problem on every MMS received (from different users), or is this an intermittent problem?
    It sounds like you are receiving an MMS forwarding message, where the content of the message is actually stored on a web server that you log into with the information that was forwarded to you.
    Please check the following MMS settings on your phone and verify that they match:
    (if not there select "new")
    Port 1: 9201
    Service Type 2: WAP
    Port 2: 0
    DNS 1: 0.0.0.0
    DNS 2: 0.0.0.0
    Time out: 5 minutes
    Speed (Bps) 9600
    Line Type 1: ISDN
    Speed (Bps) 2: 9600
    Line Type 2: ISDN
    Password: CINGULAR1
    Press Done.
    Press Exit.
    Press Back
    Press Back.
    Press the Menu key.
    Service Name: MMS
    Cant pxt or recieve tone downloads (parallel import phone)
    Please verify that your settings are as follows, and then you should be all set!
    Port 1: 9201
    Service Type 2: WAP
    Port 2: 0
    DNS 1: 0.0.0.0
    DNS 2: 0.0.0.0
    Time out: 5 minutes
    Speed (Bps) 9600
    Line Type 1: ISDN
    Speed (Bps) 2: 9600
    Line Type 2: ISDN
    Password: CINGULAR1
    Press Done.
    Press Exit.
    Press Back
    Press Back.
    Press the Menu key.
    Service Name: MMS
    Dec 14, 2007 | Motorola Mobility RAZR V3
    Multimedia issue with the Razr V3
    While you have already compared settings on the phones, check out these settings that are often overlooked regarding the Internet connection, and not just the messaging portion.
    Run through the list, and if it all matches, you should be all set.
    Port 1: 9201
    Service Type 2: WAP
    Port 2: 0
    DNS 1: 0.0.0.0
    DNS 2: 0.0.0.0
    Time out: 5 minutes
    Speed (Bps) 9600
    Line Type 1: ISDN
    Speed (Bps) 2: 9600
    Line Type 2: ISDN
    Password: CINGULAR1
    Press Done.
    Press Exit.
    Press Back
    Press Back.
    Press the Menu key.
    Service Name: MMS
    Dec 13, 2007 | Motorola Mobility RAZR V3
    Razr
    By not bothering purchasing ringtones from Cingular. Purchase "Motorola Phone Tools" and let her create her own ring tones. :) It will save you money in the long run, BELIEVE me.
    Jan 03, 2007 | Motorola Mobility RAZR V3
    Yamaha DVD-S540 DVD Player Logo
    325 people viewed this question
    Top Yamaha Televison & Video Experts
    Larry Stiles
    Larry Stiles
     Grubhead
    Grubhead
    Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
