Question about Sony KDS-55A3000 55" HDTV
Bluriness I just purchased this model (believe its the same one, bravia in 1080 p). I hooked up my directv box which is not hd and the picture is very distorted. When you view the guide there is shadowing around all of the letters and it is difficult to even look at. Is this bluriness due to the fact that my direct tv is not in HD? I knew hd improved certain channels but did not think it influenced things like tv guides, etc. Should I contact the seller about this, or am I bound to see fuziness when running non hd devices on an hdtv? Thanks so much!
  • mustangbill Feb 25, 2008
    I also just purchased a sony 55a3000 and hooked it up to my comcast cable Hd Dvr and the non HD but digital channels are very blurry or fuzzy and also some of the HD channels mostly the local channels are a bit fuzzy too . But the HD national shows such as shows like the Emmys, nascar, national news, American Idol , etc. in HD and HD movies on cable or disc are great . Any Sugesstions?
  • 979 Answers
Get the dealer back on the horn! This is not normal...accordianman
Posted on Feb 19, 2008
ILO 42 plasma P42BSMT-32 am upgrading satellite service to HD is this tv HD compatiable no HTMI port
You can get 720p or 1080i " fake 1080 " through the RGB component inputs, But you will not get 1080p true 1080 res. But, this TV is only 720p anyway. But,it will still make a big difference in the pict. up-grading. And having the new HD box when you get new your new service now,will save you $100 from needing to buy a HD box later if you have a new TV with the HDMI. As DirecTV will give you the HD boxes free with new service. But,charge later if you have up-grade from a standard box. No sure how Dish network does tho. But, not have had too many customers happy with Dish. DirecTV is the way to go. And the signal during the rain is so much more problem free.
Apr 26, 2014 | Televison & Video
Samsung LCD TV LN40A550P3F will not support 1080 format when hooked up to HDMI via Directv receiver.
Hi, is the directv box giving out 1080? There is an option on the box to select between 480, 720, 1080.
Also the tv has the same option.
Feb 12, 2011 | Samsung LN40A550 LCD TV
Sony Bravia LCD No picture, no sound I can pull up direct tv guide and all menu's but no pic or sound.
have you check other sources connected to the tv? if you can pull up directv box menu then tv is good. issue with directv box. try to unplug directv box for 1 min
Oct 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
What is the optimal cable type to connect the Samsung UN55B8500 to a DirecTV HD tuner? Are there specific TV settings to use for this cable type
The best cable hook up to use is the just the one HDMI cable. Just hook it up from box to TV and change the input selection on your TV to HDMI. Then on the Directv Box, change the resolution to 1080 for the best image.
Nov 09, 2009 | Samsung UN55B8000 55 in. LCD HDTV
How to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Apr 04, 2009 | Televison & Video
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
TV PICTURE ISSUE
sir thers no problem with your unit its the user's fault
Jun 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Connection of HD TV Issues
hdmi cables u need also set moterol box out to 1080 i if it can or 720 p ok use hd antenna for locals in hd also
Jan 10, 2008 | Audio Players & Recorders
Open Questions:
Sony KDS-55A3000 55" HDTV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
