Question about LaCie (300728U) 250 GB Hard Drive
Pc wont detect my hard drive - LaCie (300728U) 250 GB Hard Drive
  • simon fitzner
    simon fitzner May 11, 2010
    what windows version are you running and is your pc usb 2.0 compatible?
  • 696 Answers
The problem you're experiencing can have several causes.
Generally the problem lies within the the drive enclosure or the drive itself but can ocassionaly be a driver related issues with your computer.
I'll give you a few steps to try, if they work you're off and rocking. If they don't you may be beyond DIY tips but there's always the option of seeking a pro. Either way we'll give you the right advice.
Step one, plug the drive into a different computer. If it works the problem is in your computer, try a different pair of USB ports, this is important as each USB Hub controls a pair of USB ports. If the drive works on another computer but doesn't work on any of your USB ports, reply back and I'll work through that solution with you.
Step two, if it doesn't work on another computer, that serves as reasonable proof the issue is within the drive enclosure. Take the drive to your local PC shop, ask the technicians to extract the harddrive and install it in a new enclosure. If it works in the new enclosure, buy the enclosure, thank them for their time and you're ready to roll.
If it still fails to respond, the issue is in the actual harddrive. This is the point where you will need a pro to assist you. I have had great luck with Armor-IT in Canada, they are the least expensive for most types of recovery and faster than most other facilities. you can get in touch with them through their website www.aitsavemyfiles.com .
Let me know how you make out either way, if you have any followup questions please comment back into this artical as it keeps it easier for me to track your questions.
Thanks for choosing FixYa,
Crankstart
Posted on Feb 03, 2010
Disk to fat converter
Your hard drive via USB connection did not power on your hard drive so your PC can't detect the drive. I don't believe the cause is your software. Try another UBS port, if that doesn't work power down your PC, connect your drive and boot up to see if the program detects the drive.
Nov 05, 2013 | Computers & Internet
Hp pavilion g6 wont startup
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Mar 25, 2013 | Computers & Internet
NR serise wont detect hdd in bios
Nov 04, 2012 | Sony VAIO NR Notebook VGNNR460ES
How to fix asus , os wont load
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Apr 09, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Wont boot up says no hard drive detected
Check the BIOS to see if the hard disk is detected,if not open the case and re-seat the data cable on the hard drive and alsowhere it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Dec 15, 2010 | Dell Latitude D620 Notebook
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
Wont accept new windows system. harddrive has
If the issue is getting the OS into the drive, see if you can access the BIOS and see if the hard drive can be detected. If it is not detected you may have a bad disk.
Sep 27, 2009 | Toshiba Satellite A15-S127 Notebook
My computer wont boot because it wont automatically detect my har
Usually when your BIO's doesn't detect the hard drives is usually a good indicator that the hard drive has failed. In rare instants it is the motherboard. In the boot sequence it will only show the hard drives it sees if it doesn't see any then none will be shown. I would start with a new hard drive.
Hope this helps.
Mar 01, 2009 | Dell Optiplex GX60 PC Desktop
New laptop
Open the hard drive bay and make sure the hard drive is properly seated. close bay
reboot and enter bios to see if hard drive is detected in bios, if the hard drive is detected and still will not boot use recovery console to recover the OS.<ALT><F10>
If the bios does not recognize tthe hard drive, replace hard drive.
May 08, 2008 | Computers & Internet
LaCie (300728U) 250 GB Hard Drive Logo
224 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
