Question about Microwave Ovens
My whirlpool microwave model GH5184XPB-1 not working
My whirlpool microwave model GH5184XPB-1 just stopped working today. there is no power to it at all. It is just dead. I tried to unplug and than plug again but nothing
  • 3 more comments
  • wiltbank24 Feb 02, 2010
    I don't know much about microwaves, but i am good a following directions. how do I check the main plug fuse?
    I have a three pin.
  • wiltbank24 Feb 03, 2010
    My plug doesn't have a screw to unscrew it. there isn't any screw to be found on the plug.
    here is the info on my microwave if this helps.
    Whirlpool Gold model# GH5184XPB-1 accuwave system
    Manufactured June 2005
    serial number TRS2611794
    I don't have anyplace to pry open.
    here is a pic of my plug and my microwave
  • wiltbank24 Feb 04, 2010
    changed fuse still dead
  • 644 Answers
First check the fuse in the mains plug, if that is fine you will have to remove the cover, there are usually about six screws to undo at the back of the microwave then lift the metal cover until it comes off, when you have the metal cover off on the right hand side where all the workings are, have a look for a clear fuse, it should be near the top somwhere, if you cant see it straight away have a route around you will find it. Pop it out and take it to your local appliance or electrical repair shop they should be able to find a new one for you. put the new fuse into the board put the metal casing back on and tighten the screws, plug into the mains and you should get it working. post back if you have any problems.
Posted on Feb 02, 2010
  • 3 more comments
  • jimnuggats Feb 02, 2010
    What type plug do you have? A uk three pin or european?
    You will need a flathead or philips screw driver, hold the plug so that the pins are facing you, undo the middle screw, not all the way out, just until the back in your hand comes loose, turn the plug over and the fuse will be on the right as you look at it, pop the fuse out. Get a plug from another appliance like a kettle, do the same with that plug, pop the fuse out and put the other from the miceowave plug into that one, put the plug back together and test the kettle, if the kettle comes on then the fuse is fine,if it dosent then that is your problem. Make sure you replace the original fuse back in the kettle plug.
  • jimnuggats Feb 03, 2010
    Sorry about that you must have a fixed plug, with the three pins facing towards you in the centre between the pins there will be little fuse cover, each side there will be a little gap get a table knife and prise it upwards the plastic cover should pop out with the fuse. if u still cant get to the fuse try and send me a picture of the plug so i can try to point to where it is. we will sort this problem. thanks.
    Right i think the lead is straight through, without fuse so the fuse in your microwave inself is the best option follow the instructions i gave you in my first post and post back if you have any dificulties. cheers.
  • jimnuggats Feb 04, 2010
    If you have changed the fuse in the microwave, and it still does not power up, then i am affraid you will need a new microwave. But before you do that check the fuse in the same rating as the one you took out of the microwave, check to see if there any componants that you think may be blown, your looking for any dark marks on the board or a brownish colour liquid resadue, if there are any it will be those componants and they will need to changed. You could try another expert to see if they have any other suggestions of what it could be, and if there is somthing else you could repair yourself. thanks for the question i will look into further if i find anything else out about it i will post back to you. thanks.
Whirlpool gold GH5184XPB-4 Last used to cook potatoes. sensing then cooked. Now runs but does not cook. Any ideas? Joe
There are three reasons for this, a bad magnetron "common problem" or a high voltage diode and capacitor can be a factor. If the magnetron is at fault it is cheaper to replace the microwave oven.
Mar 10, 2011 | Whirlpool Microwave Ovens
Whirlpool gold gh5184xpb Everything seems to be working but it doesn't heat. If you use the buttons for popcorn or dinner plate, an error message F3H appears. Recently got a wireless router in our home...
its very unlikley to be the wireless router,,,
things like this just happen,,,i would say the magnatron had gust given up the ghost, thats the part that gets the food hot,,,safest bet is have it looked at but get ready to buy a new unit as its likley to be the cheepest way out
please dont go poking about inside your microwave,,
it will still have 1000's of volts inside it,,, these volts will kill you if you tuch the wrong part,,be warned!!!
Jun 05, 2010 | Whirlpool GH7155XHS Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
Whirlpool Microwave GH5184XPB - just off warranty. Buzzer no longer sounds when cooking is done. Can I access the control panel and replace the buzzer?
It's more likely to be a software problem, not hardware.
First, I'd give it a good reset by unplugging it for a minute or so, then plugging it back in, and trying it again.
If that doesn't work, check the settings on the menus. It may be turned off. Consult your owner's manual.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 19, 2010 | Whirlpool GH7145XF Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Microwave Ovens Logo
232 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
