Question about Panasonic SC-BT100 Theater System
When i turn up the volume on my home theater it goes to maximum by itself, and does the same on minimum side!!
  • 12 Answers
Turn unit off, then Press "Play/Pause", "Stop" and the "Power" button on the unit (not on remote) ALL AT THE SAME TIME. This should fix it. Also, download the firmware update (Google "firmware update for Panasonic SC-BT100 and follow the link to the Panasonic support site)....since I updated the firmware, mine hasn't done this again.
Posted on Feb 18, 2010
Hii I have sony shake 6D system and whenever I turn the volume up it reaches upto 40 and shows the error of 'protect E01' while the maximum volume is 50. Please help
Most likely, your unit is shutting down due to overheating. You cannot run an amp at that kind of volume very long. It is shutting down to protect itself. Try running the amp at 1/3 your normal level. Most likely, it will not shut down.
Aug 05, 2015 | Sony Audio Players & Recorders
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Lg lh t551
pre amp set to low
Sep 01, 2014 | Audio Players & Recorders
Volume control stuck
Hi Jenny,normally to resolve the problem you are experiencing,I strip the volume control and service it.You need to take it to a technician to have it repaired.Thanks Ravi
Nov 21, 2011 | Panasonic Home Theater System System
SYSTEM SHOWS ERROR CODE PROT AND SHUTS DOWN
Check the impedance (resistance) on all the speakers and the speaker wires themselves.
Power up the unit with no speakers or inputs attached at minimum volume and see if it still goes into protection mode.
Most speakers should measure between 4 and 8 ohms for most systems when disconnected from the receiver.
If the unit says PROT even with no inputs at minimum volume with the speakers detached, then there's a problem with the amplifier itself, probably in the output section.
Jun 12, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
My SC BT100 is perfect until I use the IPOD dock, it works ok for 10mins but then 'blows'. the unit becomes very hot and wont turn back on until it has cooled down.
You are overpowering the Amplifier and it is protecting itself until it cools down.
The reason for this is that the output from the IPOD is already pre-amplified. If it didn't shut down you would either blow the Amplifier or Speakers.
If you keep the volume turned down to a minimum on your IPOD and use the volume control on your theater system you should be OK but still don't turn the theater system to full output.
Please leave feedback.
Cheers
Andy
May 02, 2011 | Panasonic SC-BT100 Theater System
Bose 321 system - volume is stuck at 30
You'll need to go into the main menu and there is where you can change your on volume, minimum volume, and maximum.
Apr 02, 2009 | Bose (321GS) System
Volume Control on my SCBT100 Blu-ray Home Theatre doesn't work.
Unplug the power and let it sit. Plug it back in and it should fix. Worked for me.
Oct 12, 2008 | Panasonic Home Theater System System
Home theater
This is RCA's on line PDF manual for the rt2770. http://support.rcaaudiovideo.com/manual.aspx?product=212 The rear panel has every known hookup plus fiber optics.
I have a Question? does your rt2770 volume numbers go all the way from 0 minimum to 50 maximum, mine only goes to 41 and it does not say maximum?
Nov 24, 2007 | Audio Players & Recorders
Panasonic SC-BT100 Theater System Logo
612 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
