Janitrol GMP124-5...furnace start up sequence ends after the igniter glows...there is no ignition (main gas valve does not open). There is a ''one blinking light'' error. (message states ''gas flow, gas pressrure, gas valve, flame sensor...). I checked flame sensor and it is fine (verified via testing). What is next step to check to identify root cause?
  • 1 more comment
  • michael_l842 Feb 04, 2010
    Service company indicated they had to reset the rollout switch (then the furnace fired up). Service company says the HX is bad and it would be best to replace the 15-yr old furnace at a cost of $1750. SHould we test the rollout switch first before replacing the furnace?
    I do not smell any fumes near the combustion chamber..the furnace is 15 yrs old...I cannot see the HX...what is the best way to inspect HX?
    Would a blocked waste gas stack cause this?
    If I reduced the gas pressure slightly? Need to buy time to keep in service while I troubleshoot and shop around.
    The service company said there is a slight crack in the burner manifold, they also said a small portion of the flame is not going into the HX, especially when the blower motor comes on (flame fluttering more pronounced when blower comes on).
    The service company did not inspect the HX, just hypotheized either blockage or crack....
  • Heating & Co... Master
  • 2,597 Answers
Hi try the pressure switch, clean the flame sensor
Posted on Feb 02, 2010
Testimonial: "It sure is nice to have a cyber expert (an impartial one...who is not tryiny to sell)who knows how to troubleshoot, excellent advice and very timely."
  • 1 more comment
  • Paul Carew Feb 04, 2010
    Hi right this will all come down to the state of the heat exchanger is it split or just old , is it giving off fumes ???
    If it is old then it must be worn out so it will mean a new unit now a new reset switch is a short fix only, you will need a new funace ,but you can only buy now high effency furnaces 95 % etc so you can shop around and get discounts for having 1 fitted gov redates etc you may have seen this on the news etc ,
    hope this helps
    Hi no not the stack, do not touch the gas pressure that is set you will cause problems more than what you have ,
    shine alight up above the burner that is the heat exchanger you should be adle to see what it looks like did they sat it was split or just old ........... did they say any thing else
    Hi if the burner is cracked the you need to change the burner they can split with the heat over the years .(15 ) flame fluttering could well for burner being split , you cannot guess hx with out looking or putting a smoke peliet in the heat exchanger and see if the smoke goes out of the stack , or comes back in too the room the you know its split ,
Furnace wil, not ignite when calling for heat
For this answer, we need a model and serial number.
Generally, be sure the power is on, does the heat moving device run? (Fan for air, or pumps for water)
Nov 02, 2017 | Heating & Cooling
My furnace will not ignite
If it has a glowing igniter, that must mean it is a Gas furnace?-- LP or Natural Gas?-- We need to establish a few things like:
1.) Is there a good supply of Gas?
2.). When the Igniter starts to glow, can you hear a gas valve click'?- and then is there a small flow of Pilot gas? (over the area where the burners will need to flow gas-- so the gas in the burner tubes can be ignited safely.)
3.) There is a circuit somewhere in there, that detects that you have established FLAME-- (Usually a 'flame rod' that allows the main gas valve to open.) Can you see the 'pilot flame' touching that rod? A very small electric current is actually conducted thru the flame, -- completing the circuit that allows the safety circuit to go to the next step, before it opens the main gas valve.)
These things have to exist, before the safety circuitry allows the main gas valve to open.
Tell us more, what you observe, as you try to start it again.
Mack B
Nov 29, 2016 | Heating & Cooling
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
My York furnace sometimes doesn't completely ignite
A noisy inducer probably is headed for replacement.
The igniter can produce a healthy glow and still be defective. Mine had to be replaced with a new, improved one.
The thermocouple could be defective even though it seems to open the gas valve when it should.
The heat sensor in the bonnet could be defective. That controls main blower operation.
The heat exchanger could be cracked.
Jan 10, 2014 | Heating & Cooling
Goodman furnace Model GDS80703AXBB -fan comes on then igniter light comes on, then burners turn on but shut off right away and wont stay lit. Now igniter light wont come on so burners not coming on at...
Sounds like either the flame sensor is not working.
The sequence for starting the furnace is:
1. extraction fan on
2. pressure sensor (for fan)
3. ignitor (spark or glow plug) comes on
4. gas valve opens up
5. ignition of flame
6. flame sensor (or temperature sensor)
7. plenum temp. sensor
8. main fan starts
It is most likely that the flame sensor is dirty or gone,
or (and I hope not), the module is gone and needs to
be replaced.
Sep 10, 2017 | Heating & Cooling
For some reason the heater does not generate heat. the fan works but no heat. Any Ideas?
I've got an easy way for you to check, and then we can help you from there.
First pop open both lids to your furnace (this may require a screwdriver). Turn up your thermostat, push the safety interlock button in if it has one (it's a button that turns off the power when the doors are removed), and watch.
On most modern furnaces (past 20-25 years) you'll hear/see:
1. Inducer fan
2. orange glow (ignitor)
3. Gas valve opening and ignition (flames)
4. Main Fan.
that's normal heater operation.
The most common issue here is a burned out ignitor, in which case you wouldn't see the orange glow but the sequence would attempt to continue anyway (the gas valve will open and hiss gas, but it won't lite, then it'll give up and try again a few minutes later).
On older furnaces there's a pilot light to start with, the click of the gas valve and boom... ignition.
On new furnaces it's
Inducer fan
gas valve opening
spark - ignition
Main fan.
and there are some oddballs in between, particularly the Lennox Pulse. If that's your furnace just back away slowly and call a professional... some guys won't even touch those, so be sure to mention what it is... if you call a pro.
So go ahead and watch it run, then tell me/us what you see.
May 06, 2011 | Bionaire Heating & Cooling
I have a coleman evcon furnace and it wont work it gives me a flash code of 1 what does it mean
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Dec 26, 2009 | Tools & Hardware - Others
Furnace will not light. Igniter glows but no gas
Make sure that the switch on the gas valve is in the on position. If it is and the gas valves coming into the furnace are open, you probably have a bad gas valve.
Oct 03, 2009 | Heating & Cooling
Janitrol furnace wont ignite
it is probably a bad hot surface ignitor
Jan 29, 2009 | Kitchen Appliances - Others
Ignition failure after three attempts then sits for an hour.
try cleaning the burners and or adjust the distance the igniter is from the actual burner .
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
348 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
