Question about Dell PowerVault 110T DLT VS160 DLT Tape Drive
Lights flashing, tape won't eject
All 3 lights on the front of the drive are flashing. I've pressed and held the eject button to eject the tape. The green light is flashing, but tape is not ejecting.
  • 2 more comments
  • Anonymous Mar 03, 2008
    I have the same problem with my powervault 110t (2 1/2 yrs old). The only way I can get the tape out sometimes is to turn it off and turn on again a few times. Can't seem to run a complete backup.
  • gruetter May 15, 2008
    Same Problem: Tape does not eject. Rebooting the server and reset the Drive didn't help.
  • dannyprice Jul 01, 2008
    Same here. I removed the drive and opened the cover and can see that the tape is still pulled out of the cartridge and in the drive so I would not expect it to eject until pulling all the tape back into the cartridge. The tape is not mangled and all the moving parts that I can move manually seem to move freely so I don't know what the problem is. Maybe when I put it back in, it will work (hate those kind of fixes). Think I'm going to switch from tape to external hard drives.
  • Anonymous Jan 27, 2009
    I have the same problem, hope this helps!
SOURCE: My Drive will not eject the tape
I waited about 5 minutes and ejected the tape. It works.
Thanks for tips.
Posted on May 02, 2008
Kidyubyub
  • 143 Answers
SOURCE: Tape eject from drive
Hi. This is from Dells site regarding automatic ejection of tape once inserted:
The PowerVault 110T DLT VS160 Tape drive reads and writes DLTtape VS1 cartridges. The PowerVault 110T DLT VS160 Tape drive can read - but not write - DLTtape™ IV cartridges written using the DLT1/VS80 format. NOTE: The PowerVault 110T DLT VS160 Tape drive automatically ejects any other cartridge types and any cartridges whose format it cannot read. Make sure all cartridges that you want to use for writing are DLTtape VS1 cartridges.
Perhaps your cartridge is improperly formatted or is of the incorrect type?
Posted on May 23, 2008
  • 74 Answers
SOURCE: Tape not ejecting from drive after 60 secs pressing eject button
can you detail the model No or compaq spares No for the drive - the clicking makes it sound to me like a DAT but unable to proceed without more info.
If it is a DAT (compaq used both Sony and HP mechs) try disconnecting the scsi cable from the scsi card, rebooting the drive and trying again.
If that doesnt work try a 00pt screwdriver in the manual eject point of the drive and unload manually (about 1000 turns!)
Failing that try www.tape-drive-repair.com as they are pretty good price wise for a repair / exchange
Posted on Aug 24, 2009
Nubar
  • 51 Answers
SOURCE: I have a tape stuck in my drive and I can't eject
The only option for you is to remove the tape drive from your server, open it, and manually eject the tape that is stuck. This is not easy to do. Maybe it would be better if you remove the tape drive from the server and take it to a repair centre.
Posted on Oct 27, 2009
  • 24 Answers
SOURCE: tape won't eject
Soft power the unit down and very carefully unscrew the cover. The greatest care must be when taking the tape out so that you don't bend the unit.
Consider blowing it out to get rid of dust and it very likely has a problem that will require service. My quantum px502 had a stuck tape and I took the cover off but the picker was already off track - $700 to fix that and replace a sensor.
Consider a maintenance contract as on visit to the repair shop will cost hundreds of dollars.  And, if you get the tape out another will likely stick soon.  So service will be necessary.
Posted on Jan 23, 2010
Eject lto5
in the manual should be something like this:
Manually Removing a Tape Cartridge
If problem-determination procedures identify the tape drive as the source of the problem and you are unable to eject the tape cartridge using the eject button, reset the drive to recover the cartridge:
Press and hold the eject button for 10 seconds, then release.
The status light turns amber and the drive starts through its hardware test process.
When the hardware test completes, the status light turns green.
If a cartridge is in the drive the status light flashes green until the cartridge is rewound.
The status light turns solid green when the rewind is complete and the tape drive is ready.
Although it is from an older LTO version, it must work on the newer versions too.
I also did remove tapes, if nothing worked, but it is to much to tell and show here.
NOTE: Allow at least 10 minutes for the rewind process to complete.
Jun 09, 2014 | Computers & Internet
DLT-S4 tape is stuck in Quantum drive all 3 LEDs flashing together. Eject tape button does not work, how to get the tape out?
Hello, on some of the older DLT drives, if you press the 'eject' button several times the drive firmware attempts an unload operation. I'm not sure of the number of times you have to press it though...try pressing it in and releasing it 3 times (in quick succession). If that doesn't do anything, try 7 times.
It's worth a try!
Regards
nicam49
Nov 01, 2010 | Quantum DLT-S4 DLT Tape Drive
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
Cannot get a connection from wireless internet to game-
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
Dec 04, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Tape not ejecting from drive after 60 secs pressing eject button. I can hear it 'clicking' but no attempt to eject the tape is made. I would be very grateful for some advice regarding what I might do next.
Aug 14, 2009 | Computers & Internet
Dlt tape drive left lights blinking, internal fault
This is a hardware fault with the drive (Quite common) The drive needs to be properly repaired (Main PCB Fault)
Send it to www.tape-drive-repair.com as they are quite good at this sort of thing and are not expensive
Mar 02, 2009 | Quantum DLT 4000 DLT Tape Drive
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Dec 07, 2007 | Quantum SDLT 320 External LVD...
Ultrium LTO 2 Tape Drive
Try holding the eject button down, for a long time, about 20 seconds (1 and 2 and ). This resets the tape drive, the lights on the front should go off, then come back on again. The tape will either eject automatically or will eject after the button is pressed normally.
The only time this dosen't work is if the tape is still out inside the drive.
Aug 14, 2007 | HP StorageWorks ESL712e Ultrium (AA934B)...
Dell PowerVault 110T DLT VS160 DLT Tape Drive Logo
660 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
