Question about Sony PVM20L2 20" TV
Picture is dark...displays as mostly and redish brown wondering if picture tube may be the problem
The picture in one of my Sony PMV20LV video monitors starting going bad a few months ago...We use the monitor as a "preview" and we can no longer look at the monitor to determine shots because picture is dark
  • 979 Answers
It's time, more than likely, for a CRT...accordianman
Posted on Feb 19, 2008
My picture is redish pink
Yes it has a picture tube.
My LG 32" does the same thing and has for several months. I just turn it off and back on again and it goes away. We will get a new tv instead of fixing it.
Apr 01, 2013 | Sony KV-36FV16 36" TV
Picture is pink in places and dark scenes the picture is mostly green
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Jan 10, 2018 | Panasonic TX-36PF10 TV
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
Sony Model # KV-HA21N80 Def. Picture Tube due to redish color with retrace line. I need brand new picture tube or 2nd hand.
i have a problem with kv ha 21 m 80 t. i change the colour ic but colour are not good dot have any pre set to controll. is it controliing from the biase trassistors. green gun is not workin propaly
Jan 13, 2011 | Televison & Video
Dark display - sony trinitron kv27ts27
In the Sony TV a dark display is generally a bad picture tube. I have seen many of these and thought I could correct it with a deflection repair. I would next put the main board in another TV and saw that the board was just fine.The TV had a good picture.You can bet you have a picture tube that is bad!
Nov 10, 2010 | Sony Televison & Video
My sony shows dim, could it be the picture tube. I can see the picture when it is dark in the room; if the sun is out you can see the picture only it is very light.
picture tubes harsly ever go out i have work on curtis mathis tvs from the 70s and their tubes were great most like the leads within the tubes need cleaed in order to do theis take it to you local repair sop an they can burn the filament so that they are bright again.
Jul 01, 2010 | GE 31GT660 TV
Sony KP-51WS500 lossed it's green color...
FIRST YOU NEED TO LOOK INSIDE THE UNIT FROM BEHIND WITH THE COVER OFF AND SEE IF THE TUBES ARE LIT. AT THE BOTTOM OF THE TUBES BY THE CIRCUIT BOARDS, SEE IF ALL 3 ARE GLOWING ORANGE,(FILLAMENTS). IF THEY ARE ALL THE SAME THEN LOOK INTO THE LENSES AT TOP AND SEE IF THERE IS ANY LIGHT INSIDE. THESE SETS ARE COMMON TO HAVE BAD SOLDER CONNECTIONS ON THERE CRT BOARDS. EITHER LOST THE FILLAMENT CONNECTION OR LOST THE VIDEO DRIVE SIGNAL. LET ME KNOW, WE CAN GO FROM THERE. CAN YOU USE A SOLDERING IRON?
Dec 27, 2009 | Televison & Video
Picture not showing clear
If you use a scart connection then make sure it's in the connector tight. A loose scart lead can cause display problems.
Feb 05, 2009 | Sony PlayStation 2 (PS2) Console
Sony KP-51WS510 51 in. Dark Picture
These sets have been known to have loose welds in the picture tubes. Most likely your tubes are showing this problem.
Apr 17, 2008 | Sony KP-51WS510 51" Rear Projection...
Picture darker/less color/smaller until warm up
Hi there!
Have you checked for dust on the Tubes and mirror? This may cause a bad picture quality. Also power supply related problems like capacitors can cause a dark picture. Try replacing some of them in the power supply area and line stage.Also adjustments in the service mode,but for this you will need the service manual. Good Luck,JUS004
Oct 15, 2007 | Mitsubishi VS-55707 TV
Sony PVM20L2 20" TV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
