Question about Garden
I have a craftsman weed eater model 358.791070. The rope broke and I am down to the clutch. Is the little screw in the middle a star shape? I have star bits but they are too big. Does anyone know what size the screw is down inside the clutch.
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 246 Answers
SOURCE: r\r the pull rope spring assy
Hello:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
The Following is a "General" "Chainsaw Clutch Removal" File. **To Hold the Crankshaft for Removal of the Clutch; Purchase a Bolt that is 3" to 4" Long and has the Same Diameter and Threads as the Spark Plug. Carefully Insert the Bolt Into the Engine Until it Contacts the Piston. If the Bolt is too Short, then Slowly Turn the Engine in the Same Direction you are Going to be Turning the Clutch Until the Piston Contacts the Bolt. Now to Remove the Clutch. If you do Not have the Clutch Tool for an Impact Wrench and are Doing this By Hand (no air compressor and/or not the correct socket), then Use a 2" Wide, Flat Chisel and a Shop Hammer or a 22oz Hammer and Hit the Outer Part of the Thick Ear in the Same Direction that the Engine Turns During Operation.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
rycgl
  • 1545 Answers
SOURCE: how do I get the clutch off my craftsman weed
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Posted on Mar 20, 2011
  • 19 Answers
SOURCE: How do I remove a
Here's a link I suspect will help: http://www.youtube.com/watch?v=6FcFkbxhAXU
Posted on Oct 31, 2011
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How do I get the clutch off my craftsman weed eater model # 358791050 so I can change the pull string.
Mar 19, 2011 | Craftsman Garden
I am trying to replace the pull rope on my craftsmen 32 cc weed wacker model # 358.791580 can you tell me how to remove the clutch assembly?
There is a small T-10 or T-15 Torx head screw that is recessed in the clutch drum end screwed into the end of the crankshaft. If you loosen it, the drum should come off but the screw may still remain inside the end of the drum. This is normal. Clutch itself unscrews from threads on the crankshaft in counter-clockwise rotation. Use a blunt flat-blade chisel or the like and place on the inner ears of the clutch near the middle and strike with hammer...not real hard...just hard enough to shock it loose...maybe apply some penetrating oil to the center of it beforehand.
Aug 09, 2010 | Craftsman Garden
Weed Eater WT 3100 how do I remove/replace cutting head
If the unit has a clutch, it will spin up to the crankshaft of the engine. Try to grip the top part with something to hold it..if there is an arbor there, it can be jammed in place by inserting a small blade screwdriver in one of the holes, If the unit has no clutch (but it probably does), you would remove the spark plug...rotate the engine so the piston is down, and insert a lenth of clean soft rope in the engine so that when you turned the whole drive and crank, the engine would lock up compressing the rope allowing you to remove the head assembly.
Jul 31, 2010 | Garden
How do I replace the string on a Craftman Weed Eater model number 358.791030?
how do you fix it when the pull rope breaks ? how do you take it a part to puted a new rope on ?
May 15, 2010 | Craftsman 25cc Gas Line Trimmer
I need to find the special tool to adjust the carburator on my weed eater. What is it? Where can I find it? What is the name of it?
If the adjustment screw is star shaped you will need torque bits. You can get them at hardware store or auto store
Aug 12, 2009 | Craftsman Convertible 25cc. Gas Line...
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Garden Logo
319 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
