Question about Sport & Outdoor - Others
I have a 2005 polaris sportsman700. while riding, it started making a kinda slapping sound. stopped to see if anything was wrapped around one of the axles, found nothing. got back on,moved about 3 feet then motor just reved out. have no movement in any of the gears now, but it did roll freely still while pushing it to load up. what is my easiest way to troubleshoot this problem?
  • reedmanx1 Feb 03, 2010
    it only revs when i was apply the throttle. i think your right about it possibly being a belt. i found a small piece of a belt when i was washing off the mud this afternoon. dont hav a book for my atv.. can you suggest a easy way for me to inspect the belts?
    your advice was right on the money. found a piece of the belt when washing off the under carrige today. thanks, you gave me a good starting point
  • 506 Answers
Just a clarification first.. Does the engine REV out when you apply throttle or does it do it on its own? If it does it when you use the accelerator then I would say it could possibly be the transmission. Possibly one of the belts in the CVT transmission slipped out of place. Possibly a tensioner is bad. This would exlpain the slapping sound. Just a thought for you.
Posted on Feb 02, 2010
Sounds like a ticking noise from transmission
Probably not the tranny. Check the drive shaft to see if a bit of trash has wrapped itself around the shaft causing it to slap the bottom of the vehicle when moving.
Apr 01, 2016 | 2005 Buick Century
When my 2001 indy 500 idles i have a knock
idle knocks indicate worn pistons or worn gudgeon ( wrist pin) bushes
check the ignition timing as it may be too far advanced for idle causing piston slap
Sep 09, 2017 | Polaris ATV
Atv transmission
sounds like the connecting rod on the crankshaft.
i would inspect the primary clutch first before an engine teardown. Sometimes the engine shifts on the engine mounts and the clutch hits the cover, also check to make sure belt is not slapping around in cover.
Jun 15, 2013 | Polaris 2005 Sportsman 500 H.O
Predator 500cc.i was out trail riding and it started to bog down alittle, shut it off and when i went to start it wouldnt turn over. my lights were flickering
First thing to check would be the battery connections. Make sure the positive and negative cables are tight. I've chased problems on several atvs, especially Predators, to find out the battery cables were loose. They will make the atv cut out or bog down while riding and make lights flicker. Let me know if you need anything else, Daniel.
Oct 10, 2011 | Polaris ATV
Idling good start good but stalls if pressing throtle
there is a piece of debris floating around in the sediment bowl of your carburetor, its lodged in the high speed jet causing it to stumble and backfire......it will most likely need a carb rebuild average repair cost on this machine is around 150 dollars at a reputable polaris dealer
Nov 19, 2009 | Polaris ATV
My 2002 polaris sportsman700 winch stopped working a few mo. ago, when you hit the power switch it just clicks under the seat. Silenoid? Any suggestions.
make shure all your wires have no corosion. to see if the wich is gone you can actually hook a battery directly with jumper cable were the wires connect on the winch this will isolate if it is a winch issue
Sep 25, 2009 | Polaris ATV
Sport & Outdoor - Others Logo
15 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
