Question about Proform Crosswalk 500 Treadmill
I am looking for a Proform XP Crosswalk 580 manual.
I am looking for a Proform XP Crosswalk 580 model 831.24865.0 manual.
SOURCE: Proform Owners Manual Crosswalk Advanced 525x
Proform Owners Manual Crosswalk 380 Treadmill
Posted on Sep 25, 2009
  • 31 Answers
SOURCE: My treadmill Proform Crosswalk 400e feels like it
If it feels like you are walking/sliding on ice, the walkbelt or the motor drive belt is loose.
Posted on Jan 16, 2010
  • 10865 Answers
SOURCE: Need to replace 15 amp fuse on ProForm Crosswalk
Remove the fuse and take it to any auto parts store where they will match it up for you. Regards, Joe
ps - kindly rate my answer. thank you.
Posted on Feb 04, 2010
bwinton
  • 83 Answers
SOURCE: Belt is slipping and catching
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
Does not go all the way up or down
PleaSE run THE SOFTWARE CALIBRATION, for easy diagnose, troubleshooting and fix it.
Lube the elevation motor, see the diagram attached.and proceed
God bless you
Jan 07, 2013 | Proform XP CrossWalk 580 Treadmill
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
Look up your model on IconService.com, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Jan 05, 2013 | Proform XP 580 Trainer Treadmill
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
White powder-like substance on belt
Dear Sir:
LUBE the deck belt, is lack of maintenance, maybe you have to change the deck belt, this produce enough friction and shut down the machine for to protect the electronic system.
2) lube THE ROLLERS bearing , according with the maintenance schedule.
3) Clean any EXCESS of wax, and LUBE very well.
4) Test the input motor if there voltage the motor need repair.
God bless you
May 09, 2012 | Proform XP CrossWalk 580 Treadmill
Need manual for proform crosswalk gtx
Please go to the next web page.
www. proform.com go to customer service then parts & manuals give the model and serial number and download free.
or go http://fitness.manualsonline.com free download.
sincerely.
Oct 08, 2011 | Proform Crosswalk 500 Treadmill
Oil spots have appeared when I look at the belt of my crosswalk 580. Do I have a leak or what?
This may be caused by one of two things. One, the drive motor may be slinging oil. Two, the lift motor may be slinging oil. Open the unit up and look around both motors to see if you can see any signs of the oil. If you do, then carefully wipe the oil up.
Apr 29, 2010 | Proform Crosswalk 500 Treadmill
My Pro Form 580 XP slows down suddenly while on, and speeds up again almost making me fall off of it. Anyone know why this could happen? The manual is no help.
If you have not ever lubricated the running deck then I suggest doing so . What happens is that the lack of lubrication will tend to make the belt drag thus slowing down the belt making the motor control board to try to compensate the drag.
Apr 21, 2010 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 500 Treadmill Logo
829 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
