Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Ready tools dial broken where can l have it repair in montreal or egion or find a replacement
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Bissell ready tool dial broken
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sghs
Posted on Sep 30, 2010
How do u repair a broken rubber belt that helps spin the brush?
Hi, it's Cindy from Crucial Vacuum.
Unfortunately there is no way to fix a broken belt. The only way to repair the vacuum is to purchase a new belt.
You can purchase your replacement belts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-elite-rewind-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 27, 2014 | Hoover U5507900 Elite Rewind Bagless...
How do i replace the electrical cord for a Eureka 6996 type A The existing one will not rewind
Does the machine still run OK?
and the cord is not broken or badly kinked in any place
If so-- then maybe just the re-wind mechanism needs replacing.
This is going to require opening up the machine, and getting deep inside for repairs.
are yo equipped with the tools and patience to tear into the depths of this machine?
Another thought to consider:
The repair parts will likely cost close to $50-- is the machine about ready to fail in other areas?
How are the hoses?-- does it have necessary suction for your work? How old is the machine?
It might be good for you to take the machine to a Vacuum cleaner repair guy that you trust, and ask his honest opinion.
Jan 15, 2011 | Eureka Oxygen 6996 Bagged Canister Vacuum
LSAYS I NEED NEW BAG, PUT IN NEW BAG & STILL LIGHT WILL NOT GO OUT & VACUUM WILL NOT TURN ON
Although this generally indicates that the bag is full, it may be caused by other problems. If you have fine dust in your area, the bag may seem like it's not full, but the pores in the bag are clogged so the vacuum will shut off as if the bag is full. This can be partially solved by setting the dial on top to the smallest dot.
The problem could also be caused by a dirty afterfilter. This filter is located beneath the tool caddy on the back of the machine. Access is gained by pressing the tab on the back of the machine and lifting the caddy. If dirty, replace it. If you don't have a replacement, check to see if the vacuum will run without it. It should if there is not other problem causing the vacuum to not run.
Third, try detaching the hose, turn the machine on to see if it runs. If it does, place your hand over the in port. If the vacuum shuts off, the problem is most likely a broken, worn, or clogged Control Valve Assembly. This is the part the dial connects to. This is a problem that should only be repaired by an authorized Aerus Electrolux service tech. If you have been using generic "Made to fit Electrolux" bags, the motor and interior of the machine should be cleaned. This is worth doing as there should be a long "life" ahead for the vacuum. Periodic maintenance should be done.
You can find the nearest store using the below link.
It could also be caused by loose connections, worn or broken switch/es, broken wires, or bad motor. This can be narrowed down at the shop.
http://www.aerushome.com/storelocator/
Dec 12, 2010 | Electrolux Epic 6500 Vacuum
The question mark light on the canister of my Electrolux Epic 6500 series has come on and the vacum will not power one. This has never occurred before. It seems to be somethng with the bag but we checked...
This indicates that the bag is full, but may be caused by other problems. If you have fine dust in your area, the bag may seem like it's not full, but the pores in the bag are clogged so the vacuum will shut off as if the bag is full. This can be partially solved by setting the dial on top to the smallest dot.
How do you work it?
below is a website to retreive a free manual for yours. have the model number ready so you can find it much easier....
bye.
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_vacuum_cleaner_product_list.html
Feb 07, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I am not getting any water to come out of the floor part or tools
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Nov 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
heatman101
sghs
Aug 30, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Unit-hand tool switch
Maybe this picture will help, most vacuum repair shops should be able to get the part you need. You can also try bissell.com.
Jul 23, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Broken Smart Mix Dial-How to replace
You will have to remove the top, the knob screws on but has a stop tab. Is the plastic below the knob ok, if not then you need to replace the top cover. After you replace the knob, then put the piston on from underneath, have it set to water only selection, then put the top cover back on.
Mar 04, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
