Question about GE Monogram® ZBD6880NSS Stainless Steel Dishwasher
Ge monogram model zbd6880n00ss The wheels to the bottom rack fall off all of the time. I have no idea what happened to begin the cycle of them falling off daily, but I am wondering if I order new wheels and just snap them on, will that do the trick?
  • 619 Answers
Yes it will. part numbers are wd12x10136 and wd12x10277. 8 of each and very inexpensive. Hope this helps.
Posted on Feb 03, 2010
Why does my dishwasher heating element turn on whenever I close the door--even when it is not running?
your timer is toast. this will repeat until you replace it or unhook the element, so don't use it until repaired. you should unhook from power as this is a very big fire hazzard
Oct 10, 2015 | GE Monogram® ZBD6880NSS Stainless Steel...
I have to replace the handle / latch assembly on a GE Monogram Dishwasher Model #ZBD6600G03SS. For the love of me I can't see how to do it. Do I have to get at it from inside, outside, both sides...
Hi
If the dishwasher door will not latch on your GE Monogram dishwasher and it is a new appliance, check that the door is not hitting screws or cabinets underneath the counter. For a new dishwasher, you might also need to push in the top of the control panel as you latch the door. The new gaskets might not have had time to seat properly. It may be necessary to run up to 10 dishwasher cycles for the heat from the washer to seat the gasket, which becomes more flexible after it is used a few times. For older Monogram dishwashers, check the loading rack to be sure no dishes are protruding beyond the back or front of the racks and that no dishes have fallen through to the lower rack. If dishes are dangling down into the lower rack, they could stop the lower rack from completely rolling into the dishwasher and could also stop the spray arm from rotating. Check that no silverware is obstructing the door.
http://www.acmehowto.com/howto/appliance/dishwasher/check/doorlatch.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Aug 03, 2010 | Dishwashers
GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Wheels keep falling off on lower rack, clips all
the clips come with new wheels, they should cost about $4 for four, I would replace all wheels on the lower rack
Nov 17, 2009 | GE Nautilus 24" Built-in Dishwasher
The flimsy plastic guide wheels on the rack for my (ca. 2000) GE monogram dishwasher have been breaking. Six so far. GE wants $25 - $30 per wheel to replace and $235 for a whole new rack!! I will not...
We have just solved the problem with our wheels falling off! For .75 cents a wheel we purchased new wheel "clips". The connect straight into the wheel instead of "rotating" on. Big differnence and so easy to change out! 5 minutes and the problem is gone. The item number is WD12X10277 and it is a GE product. Hope this helps!
Mar 14, 2009 | Dishwashers
Tin foil stuck to bottom of new ge monogram oven
I had the same thing just occur. GE is now telling me the only fix is to buy a new range. Great. $10K for a range that I use once.
Jan 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
GE Monogram ZICP360SRSS - Ice cubes spill out of icemaker bucket
sorry, but not unless you want to get into spending some serious time.
Jul 29, 2008 | GE Refrigerators
GE Monogram® ZBD6880NSS Stainless Steel Dishwasher Logo
463 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
