Question about Roper REX3614KW Electric Dryer
Roper dryer ot drying very well
My dryer takes forever to dry, I ohm'd the 2 elements and the seem to be open, I think I need new elements , but I am not sure any suggestions
Try cleaning out your vent hose that runs from the back of the dryer to the outside.
Posted on Jun 02, 2008
Heating but not drying, doesnt seem to be blowing very strong through dryer vent
Hi cipera11...
I think your problem is a clogged or cogging vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me thumbs up.
Sep 11, 2011 | Amana Dryers
My Dryer takes forever to dry almost 2 hours for a load of cloths what would cause that? It is a Roper
could be 2 things,, first clean out all the vent lines, even the one that leads outside of the house,, if it is clogged at all, the clothes will take forever to dry , and depending on the clog,, may never dry,, if this checks out to be ok, your going to have a thermostat thats cutting off the heat too soon, they are located along the innser heat vent tube , and can be checked with a meter,
Aug 28, 2011 | Roper Dryers
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
Apr 11, 2011 | Dryers
Runs for 15-20 min and shuts off when restarted it will do the same
Clogged Vent
Heating Element
Cycling thermostat
This is a free answer, Please rate me.
Oct 10, 2010 | Roper REX4634KQ Electric Dryer
My roper dryer quit heating,then it did,now it dont again,also it has a burning smell when it does.
Clogged Vent
Heating Element
Cycling thermostat
Oct 10, 2010 | Dryers
Takes forever to dry clothes new element still
The problem is in the thermosta and not the element. The thermostat is bad and is cutting off the element before you are getting hot enough..
OR....
There is a problem with the vent being plugged... or the blower not working right...
Check out these tips...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Heatman101
Mar 03, 2010 | Roper REX5635E Dryer
Takes too long!
This may be caused by a partially burnt out heating element, a faulty thermal fuse, or a faulty high limit thermostat. I would start with the thermal fuse. It is located just inside the back of the dryer and is usually mounted on the exhaust duct. The components can be checked with an ohm meter or multimeter for continuity. If the component shows zero ohms, it is defective and must be replaced. Hope this helped and best wishes.
Jul 28, 2009 | Roper REX4634KQ Electric Dryer
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
firstoff, youll need to check for a clean not kinked vent, mosttproblemswith "too long to dry are genrelly tracedback to innadequate/poor venting"
Jan 26, 2009 | Whirlpool Dryers
Defy dryer, not heating
Check that you have 220v first. Your dryer will work on 110V but will not dry. You need to check all thermostats with a ohm meter (be sure to unplug dryer), they should be 2 ohms or less. Set ohm meter to 1x. If they are good go to heating element (your ohm meter should be on 1X as wel. You need to check to make sure you have continuity (however, this does not mean that it is not bad). You need to take it out and visually inspect it to make sure it has no breaks in the coil. If it does you can buy a rewire kit for runder 30 bucks for most models.
Jan 03, 2009 | Roper RES7646KQ Electric Dryer
Roper REX3614KW Electric Dryer Logo
70 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
