Question about HP Pavilion F1703 17" LCD Monitor
Screen is black. green light on ac adapter blinks briefly about every 2 seconds
  • 11,361 Answers
Look for bad solder joints in the inverter circuits, look at the round inductors (4) leads soldered to the circuit board, post or send pictures for futher help.
Posted on Feb 03, 2010
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
THE BATTERY LIFE TIMED OUT.TRY IT ON NEW BATTERY FOR TURNING ON THE SYSTEM.THE CHARGING ADAPTER MAY BR ALSO A PROBLEM TRY TO CHECK IT AC VOLTAGE LEVELS .
Sep 03, 2011 | Computers & Internet
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
URGENT! My computer doesn't switch on and Ihave a tight schedule.
please try a different ac-adapter, since its most likely defective.
if the powerled just blinks 1 time it usually indicates that the battery is empty and need to be charged.
May 29, 2009 | Sony VAIO PCG-K35 Notebook
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
HP Pavilion F1703 17" LCD Monitor Logo
467 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
