Kenmore Calypso Washing Machine
I have an FL code that keeps coming up just about every time I use the machine.  Sometimes it resets and sometime it will not.  What can I do to fix this and stop this issue.
  • 1 more comment
  • Anonymous Feb 21, 2008
    I have an FL Code Flashing. The beeper keeps sounding every 10 seconds.
    I have reset the machine unplugged it from electrical outlet, removed all cloths from the washer.
    It keeps beeping and flashing FL
  • Nicolentexas Mar 03, 2008
    I had the same problem about a year ago and finally after 3 days of resetting, unplugging and doing everything I could think of, it just stopped. Not sure what did it, but now it is doing the same thing again. I missed the class action lawsuit on the machine. Do we have any rights still?
  • Anonymous Nov 22, 2008
    Mine also started with the FL code but after unplugging and plugging back in it also turns itself on from an off position. No lights and after 5-10 minutes the machine turns itself on. Had a Kenmore dryer that did a same thing a few years ago but Kenmore is not interested.
I have had the same problem, there is too much water in the basin. I actually have a repair man coming over in the morning to replace the pump motor. There is a way to make the pump drain without cycling the washer. I cannot remember the exact process, so I will have to wait until the am to repost the solution (sorry).
Posted on Mar 12, 2008
  • kmlacost Mar 13, 2008
    To get the machine to drain after receiving th FL code, push SET DELAY TIME, END OF CYCLE SIGNAL, SET DELAY TIME, END OF CYCLE SIGNAL alternately... you should have a "dt" code now, then push the Jeans/color mode and this will activate the spin and drain test. It will drain the water out of the basin and shut off after 40 seconds.
    If this does not work, you may have a problem with the pump motor.
    I hope this helps..
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
My calypso washer will not work, the flashing light says FL ? Can you help
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
Flood Condition:
Nov 15, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite calypso washing lights on the front panel will not light up.i push the choice i want then it reads FL and all it does is hum and beep.even when off it will beep and read FL.i will turn it...
Flood Condition:
Oct 15, 2009 | Kenmore Washing Machines
Washing machine stops in middle of washing
Flood Condition:
Jun 15, 2009 | Kenmore Washing Machines
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question ^#$$%
Nov 16, 2008 | Whirlpool GSC9455 Top Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
Washing Machines Logo
295 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
