Fan isn't turning
Lately we've been using "emergency heat" upstairs because of both the recent low temperatures and because our youngest daughter's room doesn't get good distribution and so is hard to heat up.
Last night we noticed that our RUUD unit outside was making a loud obnoxious noise, and then today we went outside to take a look and the fan wasn't turning. I also thought I spotted a small wisp of smoke coming out of the unit.
My fan is a burnt fan motor. Thoughts, anyone?
  • 456 Answers
Turn the power off, take the cover off the top and try to spin it. If it spins hard then it was the motor. If it spins easy the the capacitor is probably bad which
would cause the fan to go bad.
Usually this can be a dual capacitor which also controls the compressor. Sometimes just replacing
the capcitor can do the trick, if not then the worst
is that you will have to replace the motor and still use the new capacitor
Posted on Feb 03, 2010
How to fix restarting problem on Asus desktop comptuer?
Tyler
It could be a marginal power supply, gaming puts more requirement, processing power, therefore more power is required by the CPU and the graphics card. And of you are overclocking then it needs even more power and generates more heat. Do you have a video card installed or just using the integrated video?
Another possibility is temperature threshold setting in the BIOS or some control panel tool run within Windows. If the threshold is set too low, the computer will turn off to protect the CPU. It may have something to do with the fan settings. Quiet setting for fans may prevent them from going full speed to cool things down.
Try to run a system monitor tool to see how its handling the extra gaming load.
Jan 16, 2013 | ASUS Essentio Computers & Internet
NEED TO WIRE A OIL FURNACE FAN FOR LOW SPEED IN HEAT AND HIGH SPEED IN COOL
Okay, I've got an answer for you.
If you get a Fan Control Relay that is DPDT, I think you can wire the Low Speed of a two-speed motor to the first N.O. contact, for Heat.
When the Relay trips, the N.O. contact will close, and the fan will run on low.
If it's a two-speed fan, these fans have two windings, the first for low, the second for medium, and both for High.
Wire both windings to the N.C. contact on the second half of the relay.
That way when the temperature drops below your setpoint, both fan windings will be energized and the fan will go nuts.
Of course, this means the fan will NEVER shut off.
And I still don't know why you need high speed in the Cool setting, when your thermostat isn't kicking the Relay.
Oct 10, 2012 | Honeywell R8285B1038 40 VA Fan Center with...
Weak air conditioner air flow and very hot upstairs.
Check the fans are all working ok and make sure there isn't a louvre closed in the duct
May 04, 2012 | Heating & Cooling
Why does my 91 ford econoline over heat when I turn my heat on?
I've been working a similar issue with a friends truck. When the heater blower motor is off the engine temperature gauge reads normal in the middle. But when you turn the blower motor on the gauge goes way up to the top. The engine isn't really overheating. There is an electrical problem that when you turn the blower on it is affecting the temperature gauge and making it go all the way up off-scale. So far we've found that the blower motor speed control resistor is bad. We replaced that and the speed control works now, except for the low speed setting. I suspect there is a bad ground somewhere and the bottom end of the resistor element isn't grounded anymore. As such too much current is going through the ground in the dash, which is affecting the gauge.
Feb 06, 2012 | 1991 Ford Econoline
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
Electric Heater Only works on Emergency Heat Setting.
I would say that you are on the right track.
Jan 11, 2010 | Heating & Cooling
Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
