Question about GE WBSR3140DW Top Load Washer
The knob on my GE top loading washing machine does not work when I pull it out to start the washer. It works when I push it in to select my settings but it doesn't seem to click when I pull it to start machine and no water comes out. I don't know the model number because I'm a female senior citizen and can't pull it out to check it. I know it's a supersize model and I know that it is more than 10 years old. Can you help me?
  • GE Master
  • 8,220 Answers
Try different water temps. Maybe your cold water valve is bad. You cannot get it to spin? On any cycle?
Posted on Feb 02, 2010
  • Dan Webster
    Dan Webster Feb 02, 2010
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
I have an older ge prfile washer & the cycle knob does not work. how do you take it off. i have pulled it & tried to unscrew it but neither works
pull knob out and look behind it. You should see a white plastic clip. You have to pull this out and then knob comes off. When replacing knob, put clip on knob first and then just push knob on to shaft.
Jun 10, 2010 | GE Profile WPRE6100G Top Load Washer
The dial doesn't turn with the knob pushed in, when we go to set the wash. but it does move manually with finger tips
The teeth on the knob are probably gone. To pull the knob off remove the clip between the knob and the dial and pull knob off.
Mar 01, 2010 | GE WBSR3140DW Top Load Washer
Ge washer knob just spins to turn on
Try pushing the knob in then it might turn. At least thats how my GE works.Pull it out for off,in for on.
I hope this helps.
Nov 05, 2009 | GE WBSR3140DW Top Load Washer
Cycle control GE WHDSR315 top loading washer.
Try pulling the knobs off completely and squirting WD-40 into the switch interior--work the oil in by reinstalling the knobs and moving them around. If no help, then the area behind the control panel must be accessed (pull the power plug), and the control replaced (you should have seen the mounting screws when the knobs were off).
Oct 11, 2009 | Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
May 05, 2009 | GE WJSR2070B Top Load Washer
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
May 04, 2009 | GE WDSR2080D Top Load Washer
GE washer selection knob doesn't engage
The knob it probably stripped. i would replace.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
