Question about Epson (DHV13H010L18) Projector Lamp for PowerLite 720c, 730c
The projector is projecting everything in a purple tint.
The projector is projecting everything in a purple Does it need a new lamp
Posted on Aug 23, 2010
When plugged into laptop, projects images with a purple haze
This will depend on the brand, model, cable connection type and OS of the laptop. Most have a color control which you can adjust.
Dec 05, 2011 | ViewSonic PJ350 Multimedia Projector
CPX 201 - everything projects with a purple tint.
check your cable connection attached to your computer...
Apr 27, 2011 | Hitachi CP-X201 Projector
We have an Epson Powelite projector mounted in a classroom and just recently it is projecting everything with a purple tint to it. Before that the colors were not as vivid as when we first installed it. ...
An image is produced in these projectors by passing color through three different LCD panels. One is a Red, one a blue, and the last one a purple. It sounds like the green panel is damaged. The only way to tell is to take it to an Epson authorized service center.
Mar 08, 2011 | Epson - PowerLite S1+ Multimedia Projector
My TV is about 9 years old and is a Rear Video Projector. Lately it has been losing the colors. Sometimes a lot of purple and other times a lot of yellow.
Although you may want to keep your television unfortunately your pixels die. However you may try raising the tint on the television manually (It is usually a knob on old television sets), and maybe that will lessen the effects.
Jan 11, 2011 | Sony KP-53HS30 53" Rear Projection...
Dell 2400 MP DPL Projector projects a yellow tinted image.
Clean any external dust filters or air openings in the unit.If you don't want to remove the filters, you can simply use a vacuum cleaner hose to suction away the dust from the filter element--same effect anyway. The unit probably does indeed need a thorough cleaning.
The yellow effect is most probably a burned BLUE polarizer filter located behind the blue LCD panel. (Color key--Purple onscreen=green lcd, baby blue onscreen=red lcd, and yellow onscreen=blue lcd). That's how you can tell which lcd has dust on it! Usually, the green lcd has the most free area around it and collects the most visible dust. (large purple specs) The polarizer filters can get burned due to excessive heat (not keeping proper ventilation). Of course, it might be the blue LCD panel which is failing prematurely due to heat build-up over time. The polarizer filter isn't that expensive if it can be replaced, however, the actual lcd panel IS.---Rick
Sep 07, 2009 | Dell 2300MP Multimedia Projector
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Projected image has pinkish purple tint
Simply pushing the Help Button, and then selecting, Problem with the Image, and then setting the Computer to Auto fixed the problem! Thanks!
Mar 18, 2009 | Epson PowerLite 77c Projector
Optoma h57 purple tint
Hi tassos2000
I'm afraid this is indeed a Mainboard problem that will require either repair or replacement.
You nearest dealer / repairer of Optoma Projectors in Greece is in Athens , details of the company is as follows:
LEC Hellas S.A.
31 Salaminos Street
Athens
Attica
14343
Tel : +30-210-2851948
They should be able to sort you out mate.
Thanks for using Fixya and good luck !
May 26, 2008 | Optoma H30 Multimedia Projector
Purple and green and shaking....
Hi guys
You will have to replace the LCD's .
Must warn you that it is very expensive
Dec 07, 2007 | Sony VPL CS1 Multimedia Projector
Epson (DHV13H010L18) Projector Lamp for PowerLite 720c, 730c Logo
1,564 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
