I AHVE SONY HANDYCAM DCR-HC28E BUT ITS NOT CONNECTING WITH COMPUTER WHEN EVER I CANNECT MY CAM WIH pc IT SHOW A BUBBLE MSG UNKNOWN DEVICE AND YOUR CAM DOES RECOGNIZED PLEASE HELP ME OUT. i have sony dcr-hc28e cam i want driver
    Brigadier General:
  • 3,614 Answers
What operating system do you use right now? I send you the driver for your handycam.
Thanks
Posted on Feb 19, 2008
  • micromaster
    micromaster Feb 19, 2008
    Got this link for you.
    SONY
    Regards,
    -micro
I have a sony handycam DCR HC28E. I do not know how to transfer videos from this handycam to my laptop. What should I be doing?
dear sir .... There are many kinds of video capture .if your camera is attached to your laptop check if you can simply ACQUIRE VIDEO in movie maker software available inside XP windows, check programs files folder in your drive in which windows is installed . check picture if your confused more over there are devices available in market click here or about info click here
do vote if it helps
Apr 03, 2011 | Sony Handycam DCR-HC28 Mini DV Digital...
Hi HRU? Sir pls tell me how I can copy my Movies from Cam Coder of Sony DCR-HC28E in my pc although I have connect via usb cable to my computer but no any reply i foud. So pls guide me how I can?
This is the step-by-step for downloading from your camera as found on Sony's tutorial page:
  1. Turn on the computer.
  2. On the computer, install the USB driver for the digital camcorder. Note: Only the USB driver included on the supplied CDROM will properly enable the digital camcorder for USB streaming. Alternatively, you can download the USB driver here.
  3. Turn on the digital camcorder to the VTR, VCR or PLAYBACK mode.
  4. Turn on the USB streaming feature of the digital camcorder.
  5. Connect the USB cable to the digital camcorder.
  6. Connect the other end of the USB cable to the computer.
  7. Cue the video to the beginning of the video footage to be transferred.
  8. Start the video capture software on the computer.
  9. Begin playing the recorded video in the camcorder.
  10. Begin importing the recorded video with the capture software.
Dec 16, 2010 | Sony DCR-HC28E Camcorder
My sony digital camera is unable to connect to my pc
Connect your data cable with camcorder given for the Sony Handycam DCR-TRV280 Digital-8 Digital Camcorder.And connect the other end to the Computer.If any cd available handy cam its it also. Then you can find your videos in computer
Aug 30, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Using sony dcr-sr36 as a webcam
Unfortunately is not possible directly - Your cam do not support USB streaming... But You may use any cheap video capture device like Pinnacle Studio movie box or similar to connect Your camera via S-video cable because Your camera has an analog output. Only one requirement - the capture card must have an S-video input or simply RCA video input. It's easy - connect video out and audio out of Your cam to the capture device and then connect USB of capture device to Your computer.
Sep 19, 2009 | Sony Handycam DCR-SR40 Camcorder
Unable to connect Sony DCR-PC3 handy cam to my pc
make sure that you are using the correct firewire plugs (4 pin on the camera and 4 or 6 pin on the computer depending on the computer). If you are sure you have all this correct, check your BIOS settings for a disabled media card or 1394 controller.
Apr 10, 2009 | Sony Handycam DCR-PC3 Mini DV Digital...
Connect handy cam with pc to save a video
what is exact model number of Sony handycam to help you out.
Dec 12, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
This solution is based on my assumption that you're using the iLink (Firewire/IEEE1394) port on the camcorder, and that you're using a PC running Windows 2000/XP/Vista.
Make sure the camcorder is plugged into its AC adapter, as sometimes people report problems when using battery power. If you're using a laptop PC, plug it into the mains also. Shutdown your PC completely (click the Start button, then choose Shutdown, then select "shutdown my pc" or "turn off") and turn it on again; then plug in the camcorder.
If that doesn't work, try a different port, if you have more than one. Other things to try are a different PC (might be a problem with your port, drivers, or the Windows installation) or a different cable (might be a broken wire inside the cable).
If you get the same problem when using a different PCs and different cables, you should take your camcorder in for servicing.
Dec 05, 2007 | Sony DCR-HC28E Camcorder
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
