Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Hi, Do you know where I can get a replacement grinder assembly from for this machine please
  • Gaggia Expert
  • 109 Answers
You will need to contact Saeco in your country.
Posted on Feb 25, 2010
Krups grinder squeals
Without taking the machine apart, it will be virtually impossible to know what the squealing is from or how to fix it. The device will have to be diss-assembled to examine what the problem actually is, fix it, and them re-assembled. If you camn't do it, or don't have the tools, then call a few places around town to see who can do the work and how much it will cost you. IF the machine is under warranty, and you have proof-of-purchase, it can be replaced or repaired for NO CHARGE. CONTACT KRUPS on their 1-800 number toll free line and ask for a cutomer service representative and explain your problem to them, and they will advise you.
Mar 01, 2014 | Krups 203-42 Electric Blades Grinder
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The beans go through the grinder very slow so the machine stops and the bean lite comes. Never does enough beans get ground to start the brewing cycle.
Hi, Your grinder is gumed up and needs to be removed and disassembled to be cleaned out. It works by timing and not coffee weight. If you dont clean it out, it will cause the grinder motor brushes to wear very quickly, and you,ll have to replace the whole grinder assembly. expensive. Use white out to mark the postion of the grinder assembly before you disassemble it. Can be a bit confussing when reassembly of the grinder, but take your time. Put it back together excactly how it was, and it'll be like new again, plus your coffee will taste heaps better. You can call me if you have problems 0401 200 901. Dazza Repairer
Oct 23, 2011 | Saeco Magic De Luxe Espresso Machine
Stopped grinding beans, no action when I press the grinding button
Hi, your grinder needs to be replaced. Its a pretty easy job. The grinder comes as a full assembly, new cutters and all. dazza
Oct 13, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Display saying GRINDER
my machine does not say grinder block but it saying coffee bean holder is empty when it is full.
Aug 03, 2010 | Gaggia Titanium Espresso Machine
Weak coffee
since I replaced the O rings on the brew unit I then found the grinder was not producing enough grinds - this resulted in weaker coffee - replaced the grinder with a reconditioned unit from :
kaffeestudio@web.de
Now the machine is as new and the recon grinder has a quieter motor and grinder assembly.
They are great to work with and sell all the parts with instructions and diagrams - now my 10 year old machine is as good as new.
Jul 05, 2010 | Krups Orchestro 889 Espresso Machine
I'm attempting to replace the grinder on my Saeco Vienna Espresso machine and have gotten down to the ring of ball bearings and I don't know how to remove that race to remove the motor from the plastic...
Hi
If you have gotten to the ballbearings you have gone to far. The motor includes the gear reduction portion, which is what you are working on. If you just bought the motor, you are out of luck on replacing it. It is better to buy the whole grinder than just replacing the motor. You get new burrs with the new grinder. They are already correctly adjusted.
May 13, 2010 | Saeco Vienna De Luxe Espresso Machine
My magic deluxe is grinding very coarse on number "1" grinder setting and the coffee is very weak; do you think the grinder blades are blunt? the machine is 13 years old.
Hi
Your grinder has seperated. The cork screw in the center is not centered. Grinder needs to be replaced. If you want one let me know.
Jan 21, 2010 | Saeco Magic De Luxe Espresso Machine
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Thanks for the reply :)
It could be the grinder or power board that is the problem, if it was my machine i should replace the grinder.
Try to set power to the grinder, look at the grinder to make sure what volt it should have before you by a new. If the grinder start when you power it then i think your power board must be replaced.
Let me know if i can help you more.
Best regards
/Mirran
Sep 03, 2008 | Saeco Vienna Espresso Machine
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
47 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
