Question about Whirlpool GU2400XTP Built-in Dishwasher
Is this dishwasher beyond hope? It stopped working. I cut the power, opened up the front panel and found a mess. Picture links below. http://bit.ly/b9JH4f http://bit.ly/bPqQZi Can it be repaired, and if so, what's a ballpark estimate?
  • 619 Answers
This dishwasher has a thermal fuse which will prevent power form continuing. It is located under the black cover in the console area. Has 2 wires to it and kind of sits off from the board. Change this and you will be ok. Less than 30.00. 8193762 is the part number. Hope this helps.
Posted on Feb 03, 2010
My maytag dishwasher model MDB7749SAM stopped working about three days ago. The start/resume button flashes continuously and won't turn off. I flipped the breaker switch but nothing reset. The cancel...
Most likely moisture has affected the switches in the panel or the controller is faulty.
Refer assembly shown in the link below. Open the panel and locate the ribbon cable. Carefully take it out and with a hair dryer lightly dry up the parts. Put everything back and turn power back on. If no difference still then you may have to replace the control board.
MAYTAG Undercounter Dishwasher Control panel and latch Parts Model...
Aug 01, 2014 | Dishwashers
KitchenAid dishwasher is dead
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Aug 21, 2008 | KitchenAid Dishwashers
Power receptacle in front was working till wife plugged in AC converter. stopped working after that.
Sounds like you just blew a fuse. The fuse you want to check is in the fuse panel inside the vehicle. Below is a picture of the location of the fuse panel as well as a picture of the fuse layout. The fuse you need to check is the fuse in the number 2 position. I hope this helps and good luck.
Aug 31, 2011 | 2003 Honda Element
Have a bosch dishwasher Mod. No. SGI53A55AUSS installed March 2004. All filters clear, exit pump clear and working. Switch on washer can hear exit pump working but machine does not accept water to fill....
You said you had water under the dishwasher,did you remove the lower panel below the door and check for water in the base frame as well. Bosch dishwashers have system in the base frame that detects water in base and cuts power off to every component except drain pump till it no longer sees the water in the base.
Hope this helps
Gene
Aug 03, 2011 | Bosch Dishwashers
When the unit was running it quit the display went blank? is there a fuse somewhere, all i can find is a printed control panel. DU1055 model.
Does it function at all? If not it's prob not the fuseable link. I'd put money that you have a bad contriol (the circuit board has shorted). I have the same model. Mine shut down during a wash cycle - totally dead. It has power but doesn't function. The wiring diagram (located down on your kick plate) explains how to test various components. Two things you can do when the unit has power but is dead - Turn off the power to the unit. Open the door and unscrew the six screws that hold the top of the dishwasher together. The front top control will now be loose.On the backside there is a gray cover. push the tabs back and remove this cover - make sure the power is shut off at the breaker). Under the cover you will see your circuit board and a bunch of wires. There is a 14 pin connector that connects the circuit board to the key pad. push the tabs back and lift out the circuit board. carefully unplug the 14 pin connector and leave it unplugged. Put your circuit board back in and install the gray cover over the controls - leaving the 14 pin connector unhooked. install the six screws - basically putting the thing totally back together. Leave the dishwasher door open and turn the breaker (power) back on. Count to five and close the door. If you have a bad key pad your dishwasher drain motor will cut on and run for 2 min. If the control is bad (the circuit board) nothing will happen. The control is fairly easy to replace - costs around $122 bucks for parts. Hope this helps!
Oh yeah, if you want to check the fuseable link it's the round thing on the circuit board - has two black wires going into it. MAKE SURE the power is turned off at the breaker before you mess with this.
Feb 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
The water does not drain out.it's clogged
I checked the control panel, it turned out to work correctly, the drain pump has got the juice. Then I opened up the coverabove the drain pump (1 screw, below the drain filter) and God forbids, I found a chicken bone blocking the impeller of the pump. How it could get beyond two filter levels? Somebody must have opened the filter without looking if there was anything on the top of it!
So when the drain doesn't work next time, look for the most obvious: some garbage beyond the filters.
This was a BOSCH SHU5305UC/U12 type DW and until now it is fine.
When I checked the panel, I found that the power connector (the only triple one on the left side) had some burn trace on the black wire connector. It must be an erosion due to high amperage for the heating. I'll have to get soon replacement because erosion will continue until the whole DW will stop.
Jul 08, 2008 | Dishwashers
Front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Jun 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
207 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
