Question about Whirlpool Dryers
Should I assume I have a problem with a belt if my drum will not turn and everything else seems find?
  • 51 Answers
The carbons have worn down on the motor, replacing these will solve your problem
Posted on Feb 02, 2010
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
The dryer heats, motor runs but drum doesnt turn.
Could be one of several things. The drum turns by motor and fan belt around the drum. The most common problem is that the fan belt is broken. Check to see that the drum is free and not bound up by frozen bearings. Also that nothing is jamming the drum. If everything seems to be ok --- you need to check the pulley on the motor shaft and be sure it is tight on the shaft . More than likely -- it is a broken belt. I hope this helped.
Dec 14, 2010 | Amana ALG443RAW Gas Dryer
T701 dryer makes a tumping sound. I turned the drum from the front panel area and the drum moves a little but I think it always has. I turn the drum with the belt and it seems to be tight. Any...
Hi Gary,
Since you are able to turn the drum with the belt, I am assuming that you have removed the cabinet of the dryer.
Look for worn bearings and support wheels for the drum. Also have a look at the idler / tension wheel as well.
The drum should not be moving around as it is sitting on the rollers. The belt should maintain enough tension to keep it from doing so. If it is able to be moved, there may not be adequate tension from the idler wheel.
Sep 18, 2010 | Asko T701 Electric Dryer
The dryer turns on but the drum dose not turn. It
That is definitely a very good guess. There are other possibilities (bad motor, etc) but that is the most likely by far.
Mar 14, 2010 | Asko T701 Electric Dryer
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Drum wont turn
Check the drum belt -- have to remove the top/front of the dryer.
Apr 28, 2009 | Dryers
The dryer drum won't turn. Everything else seems
If you can hear the motor running when it is turned on then you dryer needs a new belt. If you cannot hear the motor running it needs a new motor.
Apr 11, 2009 | Kenmore Dryers
Drum on my wma62 won't turn
Hi.
The main drum bearigs have failed, you have to disconnect everything you can to enable you have to
remove the whole drum and container through the top of the m/c.
It is quite an involved repair, and could prove to be expensive. more so if the drum shaft is worn.
Good luck.
if you need any further info, let me know
Nov 20, 2008 | Hotpoint WMA64 Front Load Washer
Kenmore Dryer: Drum will rotate, but only manually
Best way to confirm if it's a belt/pulley problem is to remove one of the access panels on the back of the dryer. For many models, it's on the bottom, right hand side. Open it and look inside. You also use that access panel to put a new belt on since it can be difficult to do from the front, having to reach past the drum. But if everything is intact, then you should be able to "rethread" the belt around the idler pulley and onto the motor pulley.
Here's a common diagram:
If the belt is OK, but came off the pulley, then most likely, your idler pulley has too much play in it or the spring has lost tension and isn't holding it securely. I'd put the belt back on. If it comes off again, then look into replacing the idler pulley and/or spring.
Oct 20, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
