Question about Soyo KT600 Dragon Plus Motherboard
Won't power up
Have a KT-600 DP have had it working for about 2 years. Today went to power it up and came on for 1 sec then long beep. Now this is what i have done. read troubleshooting guide. check cpu fan, replaced , checked cpu fan connector, checked. Even replaced cpu with another. Cleared CMOS (JP5) nothing , removed changed power supply. yes p4 power supply. nothing. Checked memory not problem. disconnected HD, CD, still beeping Disconnected everything but cpu, fan, electric plug and switch. still one long beep. This is not the first soyo motherboard i have had problems with I have a soyo SK-K7MP2. And guess what it does the same dam thing. And yes they were in different case's. Any other ID's Could use some help !!
  • 1 more comment
  • slimshady01 Feb 19, 2008
    Video card is a GF fx5600 Just changed it Still one long beep
    Well I double checked the video card reseated it also took some of the memory out changed it around still same thing fans come on for 1 sec then long beep.
  • la5tfa Sep 03, 2008
    Have excetly the same problem here with my KP600DP, have tried all the suggestion from this side,but peeb is still going onand can't power up th MB. 5v green leed is ok, but rest is missing .
    amateur's.
It has to do with the KT-600 series "anti burn regulator" and how it has a hard time with the XP2600 thru 3200 CPU's because they get so hot so fast... Try pressing the power on button again immediately after the long beep ends. Your computer should boot right up. Or, you can disable the ABR by removing the jumper from the pins on the motherboard. I haven't tried this because I like knowing the ABR works so good. It only takes a second or two to fry a CPU.
Posted on Aug 16, 2008
  • Soyo Master
  • 27,725 Answers
The beep are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
Make sure that your ram is securely seated
test or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Mar 16, 2011
Dude i have the same problem with that borad but i got the kt333 plus, i loved that broad. im trying to find out whats wrong with my mine doing that, but i dont have cpu and ram to try something diffnat idk, i love this broad i dont know what other broad to get on the market thats like this borad that tops alot stuff on it as a soyo greatness. can anyone help me? thanks
Posted on Mar 17, 2008
    Brigadier General:
  • 3,614 Answers
Have you changed the video card?
Posted on Feb 19, 2008
  • micromaster
    micromaster Feb 19, 2008
    Check the AGP slot & memory slot, there's possibly causing the problem, it could be some dirt or stains resulting for your hardware not contacting to circuit properly.
    Hope to hear more from you.
    Thanks,
PS3 won't reset
are you trying to get to the safe mode menu?...if so unplug for 1 minute...replug...hold power button (beep) 5 secs next beep is 1...next beep is 2 after 5 secs and power off. let go of button...repush power button(hold)...(beep)...then beep again after 5 secs...then 2 fast beeps...let go of power button. it will ask you to connect your USB to your controller then push the PS button on your controller. you should be in the menu for safe mode.(research your options there thru sony and understand what they are first before running them!)
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
Soyo k7v dragon plus motherboard continuous
2 beeps = memory problems. Since you get them even after the memory has been replaced then the problem is in the motherboard itself. Check the capacitors for bulging. If you can't find ones or you can't replace them then the motherboard is dead.
May 13, 2010 | Soyo SY-K7V Dragon Motherboard
Hi Jopav1,
At the age of *********** board, I would recommend physically looking at the board, in particular, the large upright capacitors. If the tops are bulging, or have anything leaking out of them, send the board to a recycler, and look for an exact replacement on the used market, or replace with new. I just bought the same board you have today for $25, with AMD 1800 CPU.
At 10 years of age, the battery is probably past due for replacement too. It is a standard CR2032 3Volt battery. If you replace it quickly, you may not loose your BIOS settings.
If you have a volt meter, you can check your power supply voltages. Again, your manual will show what voltages to expect at each power connector pin. A range of +/- .05V is generally allowable on all sources.
Also try unplugging all boards and powering it up. The beep should change to a sequence of 2-1-3-1 beeps, indicating that it's not able to see the video card. If you still only get a repeated long beep, It's possible that the CPU itself may have died. These are also available very cheap at this point. The fact that you are getting a cycling beep indicates to me that the CPU is OK though.
I looked up beep patterns and did not find anything for one long repeating beep for the Phoenix BIOS on your board. There is no mention of them in the Soyo manual either.
Last resort is resetting your BIOS settings to "First Birthday", and try again. This will require you to re-set any manual settings you had set previously (probably 10 years ago). This is done by moving the jumper located between the green LED, and the battery, to the two pins nearest the LED, for a second, and then back to the position nearest the battery.
Good luck
Video Flyer
Mar 22, 2010 | Soyo SY-K7V Dragon Motherboard
I need a replacement chassis fan for a Soyo KT-600 Dragon Plus v1.0, where could I buy one?? I'm not sure what size it is but it's held down over the heat sink with 2 screws.
If you are talking about the Northbridge chip set, you can buy a fanless solution from www.zalmanusa.com. It's called a ZM-NB47J. The ZM-NB47J does not require a fan, and thus does not need to be powered and does not create noise or vibration. I put one on my Soyo KT-600 system and it worked just fine. I have run all day long without any overheating.
Oct 25, 2009 | Soyo Computers & Internet
Won't turn on...hear the beep, and screen works.
Exact same problem for me on the exact same day (2-sep) as well - freaky! Unit was out of battery and I charged it but that was the last time I managed to get it working - charging it now to see if it makes any diff. Actually with mine I hear the beep and the initial splash screen shows for about 1 sec and then that's it - it seems to go off again. I think it's something to do with the battery as it seems to work when connected to the charger - not a whole lot of good to me!
Aug 28, 2008 | Garmin Forerunner 305 GPS Receiver
Getting error beeps-1-8-2-1 and I need diag. chart info
Try removing all connections to M/board except for Video card and memory and boot if computer boots with no beeps try fitting others one at a time until beeps happen that is faulty unit
if will not boot without beeps try different memory
Also check cables into hard drive are fitted correctly
stripe goes nearest 4 pin power plug on H/D CD DVD and floppy
Aug 24, 2008 | Gigabyte GA-7ZM Motherboard
Soyo KT600 Dragon Plus Motherboard Logo
325 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
