Question about AT&T Blackberry Curve 8300 Smartphone
Trackball 8800 Blackberry
My trackball moves right, left and up but does not go in or down (I can't open my mail). I tried alcohol and pushing it inside and rolling it up and down to no avail...I am in Paris with no help to seek! Thanks for answering me
    Novelist:
  • 153 Answers
Your trackball needs to be cleaned. You have two options.
1) You can send it in to be repaired, or
2) You can clean the trackball yourself.
To clean the trackball yourself:
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! (Like you should be during the whole process as all parts have very small plastic nipple which can break very easy.)
When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position.
The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from.
Once this is done put everything back together to the place each pieces came from and secure the trackball with the silver plastic ring that you removed in the first step.
Your BlackBerry’s trackball should be back working now.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Posted on Feb 02, 2010
NEED HELP SETTING VOICEMAIL.TRACKBALL IS STUCK, GOES LEFT,RIGHT,& DOWN,NO UP.NEED INSTRUCTION MANUAL.
You can download the user manual (as well as other guides) here:
http://docs.blackberry.com/en/smartphone_users/subcategories/?userType=1&category=BlackBerry+Smartphones&subCategory=BlackBerry+Tour+9600+Series
If the trackball won't go in one direction, try putting one drop of denatured alcohol onto the trackball and then moving it all around, that should fix it. If it doesn't, lift the trackball up slightly -- very gently -- with the blade of a small pocket knife and blow compressed air underneath it.
Jan 22, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Rollerball not working
On the BB 8800.......you need to have the board service....this will solve the problem on your 8800 Blackberry.
the roll ball......on the pearl....you need to have the pad on the board replaced so take it to a professional mobile technician and have that done.
Jan 03, 2008 | RIM BlackBerry 8800
Blackberry 8830 trackball gets stuck and not move to left
The trackball in any BlackBerry is the weakest part of the device. Gunk and lint get stuck under the trackball and will gum it up. You can use a small screwdriver or sewing needle to pop the chrome retainer out and then remove the entire trackball assembly. You can take the entire thing apart but I would not suggest it unless you've got the skills to put it back together. Soaking the assembly in alcohol might do the trick.
Sep 28, 2009 | RIM BlackBerry 8800
The speedball wont move to the left
Your trackball is damaged you need to get a replacement for it or you can pop it out and see if anything is just shifted out of place in that case you can just shift it back into place and carefully put it back in and then it should work just fine.
Kyle
Jun 04, 2009 | RIM BlackBerry ® 8830 Cellular Phone
The ball won't scroll down
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
May 30, 2009 | RIM BlackBerry 8800
How do you turn on a blackberry 8800?
If the battery is fully charged, it should turn on by pressing the button with the red phone reciever on it. Its to the right of the trackball next to the bent arrow button.
Dec 25, 2008 | RIM BlackBerry 8800
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Bb8800 the pearl/cursor does not scroll up
This is usally caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Oct 12, 2008 | RIM BlackBerry 8800
Trackball moves but cursor will only move down and left to right not up
try takign out the batery if that doesnt work click it a bunch of times to losen it up
Mar 27, 2008 | RIM BlackBerry Pearl 8100
AT&T Blackberry Curve 8300 Smartphone Logo
197 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
