Question about Kenmore ProSteam 62888 Iron
I have the psp 2001 digital steam press. How does
I have the psp 2001 digital steam press. How does is turn on?
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
I have a Swan S15040 steam generator iron, the stand by light is permanently flashing, no matter what temperature setting i put the iron on. No steam is generated. I have tried holding the steam button...
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
Jul 18, 2009 | Black & Decker Steam Generator SG200 Iron
Solenoids workin, steam lines fine, but no steam
take hose off from iron end,press iron button ,breifly! keep tight hold of hose [best to put towel around hose while holding]see if steam comes out.if not hose could be blocked, then take hose from solenoid end and press button .if no steam comes out the solenoid is either faulty or the valve hole inside is blocked,turn off power and take nut off top of solenoid ,check spring and plunger for condition.the small hole may be blocked in the solenoid housing,try a needle in the hole to clear any blockage.
Jun 24, 2009 | Irons
Steam Press sp-660 will not steam with distilled water
Steamfast brand SP-660 steam press
contact Top Innovations
1-800-711-6617
Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Cleaning Ironing Steam Press
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and
this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do
this if it is teflon coated. Hope this helps you.
George
Jul 11, 2008 | Yamata PSP-990A Iron
Breville ir23 steam iron
My electronic steam press has been performing perfectly until yesterday. I can not longer get it to turn on? Any suggestions? carolb745
Jun 17, 2008 | Singer Electronic Steam Press Iron
Kenmore ProSteam 62888 Iron Logo
638 people viewed this question
Top Kenmore Irons Experts
Steve
ray gallant
Tom Chichester
Are you a Kenmore Iron Expert? Answer questions, earn points and help others
