Question about Epson Stylus NX300 All-In-One InkJet Printer
I have a new Epson Stylus NX300 Series. When I
I have a new Epson Stylus NX300 Series. When I went to print it showed I had no ink in the cartridges. So I went to Best Buy and purchased new cartridges. I spent $58.00 and I am not a happy camper. Can you help me. It still shows that my cartridges are empty. Diane
  • 240 Answers
Diane,
We try to steer people away from new Epson printers unless they plan on purchasing a professional model. The new Epson cartirdges have little ink and finicky. I would try power cycling the machine with the cartridges removed (unplug it for 30sec.) then reinstall the cartridges. If the problem persist call Epson and let them know what you think. If they don't help you, buy an HP. But but an HP that takes integrated print head cartridges or you'll be in the same situation.
Pat.
Posted on Feb 03, 2010
Why does my Epson Stylus NX300 print a rainbow color band at the bottom of vertical 4x6 pictures
DOES THIS COLOR SHOW UP ON YOUR PRINT PREVIEW?
IF NOT, THAN GO INTO PRINT CARTRIDGES ON YOUR COMPUTER AND CLEAN THEM UP!
THAN DO A TEST ON A SEPERATE PIECE OF PAPER THE SAME PICTURE TO MAKE SURE IT HAS STOPPED WITH THE RAINBOW PROBLEM YOU'RE HAVING.
YOU MAY ALSO HAVE PICTURE SETTINGS WRONG ON YOUR COMPUTER, YOU CAN CHECK THESE UNDER PRINT PREFERENCES.
IF NON OF THE ABOVE WORK, THAN TAKE YOUR PRINT CARTRIDGES OUT AND CLEAN THE CONTACTS WITH SOME RUBBING ALCOHOL AND A Q-TIP.
Aug 25, 2011 | Epson Stylus NX300 All-In-One InkJet...
Out of Magenta but just want to print in black and the Epson nx300.won't let me.
strangely enough, epson printers require all cartridges to have ink in or they don't seem to work.
Jun 01, 2011 | Epson Stylus NX300 All-In-One InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Reconfigure epson stylus nx300 ink cartridges for refilling? Tks
The only way you can do that is by using a chip re-setter. They have them in refill shops, and I think you can buy one on e-bay.
Jan 20, 2010 | Epson Stylus NX300 All-In-One InkJet...
How do i get the ink cases over to where i can change all the ink colors
Turn on the Epson Stylus.
  • If a cartridge is expended, you see a message on the Epson Stylus display screen. The icon on the screen indicates which color to replace. Press OK.
  • If you're replacing a cartridge before it's expended, press the Copy/Fax button, press the Menu button, press cp_button_43_er.gif or cp_button_44_er.gif to select Maintenance and press OK. Then select Change Ink Cartridge and press OK.
Sep 24, 2009 | Epson Stylus NX300 All-In-One InkJet...
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
How do I change cartridge for Epson Stylus nx300
If ink out message appear in status monitor, follow "How to..". Or Turn on printer, imediatelly unplug power while carriage moving. Then move carriage by hand to replacement position. Turn on printer.
Sep 17, 2009 | Epson Stylus NX300 All-In-One InkJet...
Epson stylus cx5000 series
i cleaned the post where the ink cartridge slides down on with alcohol. they could maybe be called the print heads i am not sure. but it is for sure this model cx5000 loves ink!
Aug 18, 2008 | Epson Stylus Multifunction Inkjet Printer/...
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus NX300 All-In-One InkJet Printer Logo
569 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
