Question about Kenmore 64802 Top Freezer Refrigerator
Where is light in freezer section - Kenmore 64802 Top Freezer Refrigerator
    President:
  • 1,218 Answers
Good day,
It should be in the back right rear, however, some models were made without one.
Posted on Feb 02, 2010
  • Kenmore Master
  • 8,220 Answers
I do not believe their is one
Fridge freezer not working and fridge interior light comes on but is very dim
There is an Evaporater fan located in the back section of your freezer and depending on year of the fridge supllies the air flow to the freezer and fridge section and may use a circuit board or may not. On Fridges newer than 2002 they use cuircit boards prior years do not. The power to the evap fane is shared with the light in your freezer and a locked up fan can cause no cooling and draw too much amperage and cuase the light to be dim. My suggestion before trying to diag is go to www.aplliancepartspros.com and look up your fridge by model number and locate the diagrams for the freezer section and you will have a better idea what you dealing with.
Sep 24, 2012 | Refrigerators
Freezer is wporking but refrigerator is not working
Is there frost in the freezer section on the back wall? Is the fan motor in the freezer running? What is the current setting for the freezer set at? Is the lights in the refrigerator section remain on when the door is closed?
Just need more information to help you
Aug 28, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Replaced 30 watt bulb in refrigerator section with 25 watt bulb still will not light otherwise working well, my be switch . freezer section light works
Either the door switch or the light socket is bad. Disconnect the refrigerator and pull the switch out and test it with an ohmmeter for continuity.
Jan 06, 2011 | Samsung RB2155SH Bottom Freezer...
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 64802 Top Freezer Refrigerator Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
