Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Kitchenaid refrigerator w/bottom freezer french doors
My bottom freezer works fine but my refrigerator does not cool. Lights and everything else works fine. I pulled out my refrigerator and cleaned the dust off and the fan in the back compartment is working but no cold air is keeping the refrigerator cold. The thermostat is digital. I tried unplugging everything over night and replugging everything back in the morning.  Freezer is freezing up but still nothing in the refrigerator. Any thoughts?
  • 2 more comments
  • Anonymous Jul 05, 2008
    Same problem. Fan in the freezer which is supposed to be blowing is barely spinning. Vent up in the fridge is open. Probably something to do with my fan down in the freezer I am guessing?
  • bergwall Dec 26, 2008
    my freezer is working fine, but the refrigerator is not. I have it turned up as high as it will go. No cold air coming in through the upper vent. Any suggestions?
  • Anonymous Mar 12, 2014
    Cold air is coming from the fan at the bottom of the refrigerator and I must keep the settings on both the freezer. And refrigerator on hi to be cold enough.
  • Anonymous Mar 13, 2014
    top-freezer refrigerator The bottom of refrigerator will not cook even when turned up as high as will go. Everything is warm. The top keeps cook but not as cold as it should be. How do you take out the filter for cleaning/
  • 958 Answers
Please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Posted on Feb 19, 2008
Did this solve the problem? I have the same issue and would like to try resolve it. Thanks.
Posted on Jul 05, 2008
My fridge isnt working but the freezer is still on and running fine. Before I call a repair man any suggestions??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 07, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
My Maytag french door, bottom freezer stops cooling. I can hear it humming, the lights are on, but the temp in both continue to climb. We moved everything out,and after several hours, it started working...
It's possible, it may be your high voltage control board, going out. If your model has one of these, it will be located on the outside of the machine, on the back.
Mar 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
Everything in the freeze has a thick layer of ice
Typically, this is an indication that the seal on the door needs to be either cleaner or replaced. begin by cleaning it thoroughly, also clean the frame of the door. Then defrost the ice using a blow dryer and dry it. Then over the next few days you will know if it is the seal if the ice forms again.
Dec 05, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Dec 24, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
540 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
