Get a error 5 code on my washingmachine
Hi when i start my machine the error 5 code shows on the display before it even take in wate.r ( im from sweden so my english is not very good)
  • stefanerzen Feb 02, 2010
    hi again what i could find was MOD HNF 9167 N 3100081505443180 G 0001
    and its a hoover nextra 3d i hope that will help you.
  • 11,896 Answers
What is the make and model number of your machine?
Posted on Feb 02, 2010
  • Nate Stansfield
    Nate Stansfield Feb 02, 2010
    Thermostat/Heat faulty.
My washingmachine started to beep and FH showed up on the screen. What does FH stand for?
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Feb 16, 2011 | Whirlpool Washing Machines
Hello. I have samsung wf8604nwg washingmachin.and now theres a message that says HEI at the screen. what can i do to fix this?
WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
Jan 01, 2011 | Washing Machines
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
STARTING PROBLEM OF FRONTLOAD WASHINGMACHINE
If the error code is DE, then you need the door lock assembly.
I will need the full model number to find the right part number.
Mar 13, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What do I do with a message saying 'Wate ink near full'? Can I replace the absorber myself?
hI try
How to reset error 5B00 for Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
All Best: Pineworks
Jan 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Fisher and Paykel Kelvinator Washingmachine All lights on n
too many clothes in the washer maybe
hows about a F&P manual?Gimme a dollar LOL!
Sep 13, 2009 | Fisher Washing Machines
Exactly the Same Problem
It's difficult to say without seeing the machine or having a failure code.
The machine looks for a switch to close as it fills with water. Maybe a pressure switch?
You could find the switch and see if it clicks when blowing into it and even test it with a meter.
That's an easy test.
Maybe the module has failed.
Hope it's given you something to look for.
regards
john
Aug 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Jul 31, 2009 | LG WM-2277HW Front Load Washer
Kenmore Elite 42922 HE 3t
sojds as if theresnot addeguate wate rsupply going to unit make sure
both hot and cold water is supplied and working to the unit
Apr 02, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
