Question about Microsoft Xbox 360 Console
I'm in Germany where outlets are different so we have to use a converter box. My AC adapter is not cooperating and has a yellow light until you try to turn it on and then turns red. Whats the problem?
  • Microsoft Master
  • 5,568 Answers
What type of 'AC adapter'? And 'converter box?'
Since the power supplies are pretty certainly 'switched mode' the 50 Hz line frequency shouldn't bother it so all you should need is a step-down transformer (220-110 VAC) unless the 360 specifies (for example) 100-250 VAC in which case you should need nothing other than a plug adapter. If it is specified only for US power (~120 VAC) you may be able to get a step-down transformer from the local German utility. When I left there (many moons ago, I confess) they provided these on a free loan basis.
Posted on Feb 02, 2010
Dell latitude D505 battery not charging
Take Dell latitude D505 battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Mar 31, 2013 | Dell Latitude D505 Notebook
Tha half moon light blinks green,standby light also blinks with battery light orange light when charger is connected to my thinkpad t61p ,no booting
Step 1:
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Feb 17, 2013 | Lenovo ThinkPad T61p 15 inch widescreen...
HP Compaq NC8430: Laptop does not want to charge battery
Jan 30, 2013 | HP Compaq nc8430 Notebook
Windows 7 battery not charching
Im assuming its a laptop ?
Jan 28, 2013 | Microsoft Windows 7 Home Premium 32Bit...
Battery not charging
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the Battery Sometimes it's as simple as a seated battery.
hope this helps
Jan 25, 2013 | HP Computers & Internet
My laptop battery willnot charge
For this kind of issue, you may try the following troubleshooting steps:
Take your laptop battery out, plug in the charger and see if the laptop works.
hope this helps
Jan 08, 2013 | Advent Computers & Internet
Battery wont charge
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Hope this helps.
Jan 06, 2013 | Computers & Internet
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
My dell inspiron 640m display plugged in, not charging. i need help please.
More than likely this is a problem with the AC Adapter. Many of them have lights on the actual converter box, if the light is on we can narrow it down to a problem sometime AFTER that converter box. This meaning it is a problem with the cable leading from the AC converter box to the laptop, the connection from this cable to the computer, or the jack located on the motherboard. Also, because you said it is not charging I am going to assume that the charge light (normally has a lightning bolt indicating power) is NOT on on the actual laptop. If the light on the ac adapter is not on, of course you'll want to check the connection to the wall and try a different wall outlet as well. Sometimes I'll even go to the point to plug a lamp or something into that outlet to make sure the actual outlet is working properly. Check the AC Adapter for any damage, on the cables or otherwise. If you find something here the best option is going to be to replace the ac adapter. I have a Dell Inspiron 1525 and the cheapest one that I found was @ Amazon.com.
May 05, 2011 | Computers & Internet
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Microsoft Xbox 360 Console Logo
70 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
