Question about Canon PowerShot A95 Digital Camera
Battery compartment door replacement - Canon PowerShot A95 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Http://uscamera.com/cm1-2504.htm
Posted on Jun 14, 2010
ReplacementdoorA570cannonpowershot
Hi
If you are looking for a replacement door for the battery compartment of you camera i would suggest the following.
Simply search for a Faulty Cannon power shot A570. Faulty ones sell for a lot cheaper. Then just replace the doors of both camera. Ebay is a good place to look.
Jul 21, 2013 | Cameras
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
Broken door to battery compartment
Here's a possible source, though I'd check to see whether the battery covers for the ist and the *ist are the same.
http://uscamera.com/istd.htm
Jul 05, 2010 | Pentax *ist DL Digital Camera
I cannot find a way to open the compartment to change battery in mouse. Have pressed button and pushed and pulled - nothing
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Mar 28, 2010 | Logitech Cordless Mouse
Compartment door will not shut properly, camera will come on
Drill 2 tiny holes, large enough to insert thin paper clip wire. One hole is drilled in the battery compartment door, close to the sidewall but in between the 2 adjacent batteries.
Drill second hole in battery case by first peeling back the ruberized coating slighty. This hole should be adjacent or sighted in line with the first hole. In each case, allow enough in tact plastic door or case so that it can withstand the pressure of a tightened piece of wire. Insert batteries. Then insert wire carefully tto penetrate both holes. Press down hard on battery compartment door and carefully twist the 2 ends of the inserted paper clip wire to secure the compartment door tightly. The one drawback is that each time you wish to change batteries, you will have to follow the above procedure.Don't know of any recalls on this condition.
Sy25 syfish@aol.com.
Nov 21, 2008 | Nikon Coolpix 990 Digital Camera
Replacing battery cover door on Canon AL-1
Very easy to replace door. Remove base plate (3 screws). Remove 1 screw found in battery compartment. Lift corner of battery compartment (right where you took the screw out) up about 1/4". No more or you will break the opposite corner. Use a piece of picture hanging wire and push the hinge pin from the outside toward the inside until you can grab it with tweezers and pull it right out. Rest is simple.
Sep 09, 2008 | Canon Photography
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Canon PowerShot A95 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
