Question about Dryers
The empty water wanrning light will not go out. I
The empty water warning light will not go out. I have emptied the water tank,cleaned the filters and condenser unit. The dryer tumbles but does not appear to be heating up.
  • 51 Answers
There is a float switch at the pump that has become stuck, and when this happens, the "empty water" light will stay on and the machine will operate but with no heat. just locate the floating switch and give it a light tap back into its place, this will solve your problem.
should you have any problems you can email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 02, 2010
I have a new hotpoint Aquarius and has not been used and the clean filter and empty water light is coming on How do I resolve this
The empty tank & clean filter light will come after EVERY use of the machine,
because it is reminding you that this is what the user manual tells you that you're supposed to do EVERYTIME you use the machine.
If the machine breaks down because it's full of fluff, it may invalidate your warranty & a water tank with just a little water, is a lot easier to empty than a full one.!
Mar 10, 2018 | Hotpoint Washing Machines
Why is warning lights on on my AZC6470 Whirlpool condenser dryer when i have cleaned heat exchanger/filter and emptied water container
Not trying to be a smartass but what does the manual say about the warning lights as in what do they refer to.
Oct 09, 2014 | Whirlpool Dryers
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Beko condenser dryer
check dampness senser may still have lint trapped around it
also poss. stuck button on control board
Dec 06, 2013 | Dryers
I have a Siemens e44-10 dryer. It works for few mins and that stops. The light looks like. Up of water flashes. I cleaned all filters, and the water tank is empty. Can u help me?
I had the same problem above. I tok the side panel off and disconected the float and cleaned it. I noticed alot of water mixed with dust. I used a dry cloth to get the water away and made sure the reservour was clean. I assembled everything and it is all working. Tips, make sure the condense tray is emptied after each Washington aswell as the dust filter. Clean out bottom filter once a month. This saved me having to buy a new machine and tok just half an hour. Phew, money in the pocket!
Aug 03, 2012 | Dryers
RE: R/O system. Model # PNRQ20FBL Serial # TM30938P This system was in our home when we purchased it in Aug, 2009. The home was less than a year old - so the system was...
is there a precharge of air in your tank. when empty of water th?re should be about 1 bar or 14psi of air. water must be able to empty from tank. pump air in until all water is gone. if unable to empty tank has failed. also if a pumped unit, when changing filters ensure all air is bled through pump before turning it on toprevent air locking inside pump
Feb 28, 2017 | General Electric Profile Smartwater Ultra...
The tank empty light won't shut off even with water in the tank.
The float valve is probably stuck. Empty the water out of the reservoir and clean the tank with 50/50 White Vinegar and water.
Feb 09, 2011 | Sunbeam 1117 Humidifier
My pulsar 150 is showing a missing when it goes to reserve
It probably is due to the crud that is around the filter in the bottom of the tank.
Petrol is messy stuff and as it is a hydrocarbon it contains water.
Water rusts the tank this sinks to the bottom and after a while gunges up the filter.
If possible empty the tank fill with a small amount of fresh petrol and swill it around and empty again. If you can remove the filter from the tank clean it in meths or clean petrol. An old toothbrush works well.
Jan 27, 2011 | 2005 Bajaj Pulsar 150
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
Dryers Logo
937 people viewed this question
Top Dryers Experts
