Question about Hotpoint Washing Machines
Programme not finished on/off button flashing won,t restart
  • Hotpoint Master
  • 3,463 Answers
As you do not specify model, itis difficult to give you an accurate answer to your problem.
If it has a start/cancel, or reset button, then switch washer off, wait a few seconds, then switch on again.
Press and hold start cancel button for 3 seconds, and then try to programme it again.
This is not guaranteed to solve the problem ,as I say, you do not specfy the model number.
Posted on Feb 02, 2010
Problems with programme (washing cycle) how to reset
Her indoors did this on a regular basis, I just held in the power button until the display flashed and it reset itself. Good luck
Jun 30, 2014 | Zanussi ZWD12270 Front Load Washer / Dryer
Can't get my machine to start after programme has finished
I find quite often I have to turn it anticlockwise for it to allow me to start it again, or wait for a short while (my plug is behind the machine)
Mar 31, 2014 | Russell Hobbs RH1042 Frontload Washing...
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
What does control lock mean?
This means that the machine will not respond to any controls and will have to finish its current programme completely before it will respond to any operator controls again. It is very useful to stop anyone changing the programme mid cycle. It also means that if the power is cut or you have a brown out that the machine will just carryon where it left off and finish the programme.
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Green light is flashing and it didn't finish cycle and won;t restart
had same problem,,sears replaced the touch keypad and the related circut board
Aug 03, 2009 | Kenmore Dishwashers
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
