Question about Garden
I took down my craftsman 1/2 hp door opener to replace the gear, now that I have it back up , i cant remember which order to hook up the wires for the door sensors. plus after taking it down one end of the rail rail fell to the ground, i had it proped up and someone decided they needed my prop. now i can't open the door manually, it goes up part way , but where the brackets are supose to slide over each other they don't help please
  • Peggy Dickinson Feb 02, 2010
    thanks for the wiring info
    ok the door is unlocked and i can manualy pull it up about 4 feet.
    there is a sliver bracket on the rail that has a long screw on metal lline attached to it I assume that is where you adjust the tenison on the chain..
    so when i pull t he door up, the arm where you can pull the string to locked the door won't slide over the bracket ,therefore i can't get it up.
    any ideas
    i took down my craftsman 1/2 hp door opener to replace the gear, now that I have it back up , i cant remember which order to hook up the wires for the door sensors. plus after taking it down one end of the rail fell to the ground, i had it proped up and someone decided they needed my prop. now i can't open the door manually, it goes up part way , but where the brackets are supose to slide over each other they don't help please
    President:
  • 1,901 Answers
Well we can take care of the wiring problem. The other may be more of a problem without actually seeing what is what.
For the wiring:
You should have a white and a white/red stripe wire coming from the door opener console/switch. The white wire goes to post #2 on the opener and the white/red stripe wire goes to #1.
Then you should have 2 pairs of bell wire coming from the sensors. Both have a solid white and a white/black stripe wire. Both of the white wires go to post #2 and both of the white/black stripe wires go to post #3.
As far as the door brackets, first thing I would ask you check is to see if the manual handle is pulled before you try to put it up. The latch mechanism should be like an L. If it is like an I it is locked out. Pull the emergency release handle toward the opener to place the latch in the L position. It should connect the next time the opener is activated. Like I said it is very difficult to understand what exactly is happening without seeing it.
Posted on Feb 02, 2010
  • Wayne Mineard
    Wayne Mineard Feb 02, 2010
    The small latch that the emergency handle is attached to can be in one of two positions. Straight up and down, or at a 90 degree angle. Try both positions and see if you can get it past the brackets.
I have craftsman 1/2 hp door opener and when the door has been down for three to five hours it will just open up by it self
Disconnect the wire from terminal #1 on the rear of the motor unit. This will disable both the wall control and the wiring to it. If this stops this problem then you can by a process of elimination determine if it is the wall control or the wiring. Replace the wire at terminal #1 and remove the wires from the back of the wall control. Remember which wire goes where. If your problem still doesn't happen then the wall control is bad.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage door goes up only about
Release the door from the opener and operate the door by hand. Check the weight of the door. If it is heavy check the door springs. One could be broken. Also take another look at the gear you replaced. Did you use the lubricant on the gear? If not the gear will not last.
Mar 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp garage door opener, model 139.53970SRT, 8-99 Was working fine, then the plastic drive gear got stripped. I replaced the worm and drive gears and all works great mechanically, except...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTMAN 1/2 HP OPENER
You say it only opens two feet?? Then closes?? If I may if you a little bit more costly option. Dont replace the gears. They used to be really good 8 years ago but the way they make the gears now there too soft and often strip out much faster. I would suggest that you do what we call a motor head change out. Take off your old chain drive motor head and buy a new one. Pretty simple. Two things though one always make sure you put the new one in with the door down. And the traveler in the down position ( The traveler is the metal thing hooked up to the chain) but far and your gear that you have it sounds to me that you dont have the gears close enough.. but 100 percent on that but a door should never close on it own. It's not safe.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp opener
I am sure that your lift gears have stripped and need to be replaced.
Sep 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener
you can order a new gear kit from amazon for $20. It's and easy fix.
Dec 12, 2007 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
