Question about Maytag Neptune MAH5500B Front Load Washer
Replaced Motor Control, motor and Main Control board, but still won't work
Dear washer experts:
When I saw the fuse blown in the motor control, I purchased the replacement kit that replaces the old motor control board and a new motor. I also replaced the main circuit board, however, the machine fills with water, but when it comes time for the motor to actuate, the on light goes off. A few months ago, I had also replaced the wax motor for the door and it ran fine then. So I think the problem must be something other than the four parts that were just replaced, namely: motor, motor control, main circuit board and wax motor. Do you have any suggestions.
  • Anonymous Mar 15, 2014
    Had to replace electronic control module in january the first time I saw this code. Replaced four days ago again, washed three loads of cloths and the code has appeared for the third time.
  • 96 Answers
The only other thing that could cause the ON light to turn off as soon as the motor is about to start would be a bad or loose connection that causes a break in the circuit. Even if the components are O.K. the connection could still be causing the problem.
Posted on Mar 02, 2008
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My fisher paykel GWL11 will not power on. Outlet is working. Just last week I replaced the pump motor and I was doing laundry again. This last time I was doing laundry , it did not fully spin dry the...
Did they add a fuse and fuse holder to the pump motor wiring? If not it may have blown the 6.3 A fuse on the motor control board as mine did before I replaced the pump... Did you replace the pump yourself or had a service man do it? If you had someone replace the pump, a return warranty servicve call is in order. If you replaced it yourself you may need a motor control board...$135 + shipping.. Arggh!
I plan to post my lessons learned on my pump/motor controll bd. problem shortly
Oct 07, 2011 | Fisher and Paykel GWL11 Top Load Washer
No spin only drains
Almost certainly the motor capacitor is blown. Normally it is a 16micr Farad. value. Dont continue trying to use the machine until replaced.
Jun 05, 2010 | Whirlpool LHW0050PQ Front Load Washer
LR CODE ON A NEPTUNE 55OOBWW WASHER
Hello there:
The LR error on your non-spinning Maytag Neptune is usually, thoughnot always, accompanied either by a burn spot or a blown fuse on theMotor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge)Either way, it means just one thing: a new motor and motor control board kit are in your future.
Hop this is very helpful for you
Best regards Michael
Dec 29, 2009 | Maytag Washing Machines
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Display board not work
Solved problem. Replaced main Control Board. Works like a charm, hopefully willl last like one too!
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
400 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
