Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Blowing air out and not vacuuming - Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
  • 268 Answers
This usually means you have a blockage between the roller brush and the bag in the machine. You won't have any suction to pull dirt into the bag. The dirt will fall back onto the roller brush and out the front of the machine.
I hope this helps
Posted on Feb 03, 2010
  • Ratchetgirl
    Ratchetgirl Apr 01, 2014
    Yes, the hose between the roller brush and the bag was plugged. Cleaned that out and my vac works great! Thanks, WonderTech.
I have a sears 12 gallon vac/ blower. It is blowing air, how do I get it to vacuum.
If it is blowing air, then that air must be getting in, to be blown out. That inlet is where the suction occurs. Check all seals and filters.
Aug 17, 2014 | Vacuums
Why is my karcher wv50 blowing out water through its air vents
Have you over filled it and tipped the karcher to one side that sometimes makes warter blow out the vents give it a good shake on its side then try again.
Jul 31, 2014 | Karcher WV50 Window Vacuum
Filter blowing out of vacuum
If you have an air compressor try blowing all the dust out of the inside of the machine, Did it to mine and it works a whole lot better.
May 19, 2014 | Kenmore Vacuums
Eureka vacuum blowing dust into the air
Check the leak (where the dust come from); maybe you need to tighten or reseat one or more part in that area.
Feb 09, 2014 | Eureka AirSpeed One Turbo Bagless Upright...
Hello,i have a vacuum cleaner but their is no air pressure in it
Do you mean the suction is very low? Or really none at all?
If low, there can be a hair/dust ball clogging the tube way deep. If you can remove it and the vacuum cleaner has an 'blow air' out you could connect the tube and blow the junk out possibly. The clog could be inside the unit instead.
If no suction at all then it's probably a complete disconnected tube somewhere.
Oct 06, 2013 | Oreck UPR014T XL Pro 14 Upright Vaccum...
How to blow up a mattress with a Dyson dc25
the Dyson upright does not have an exaust outet you can plug a hose into to blow up the mattress, I had the same problem and Dyson told me that basically you can't reverse their vacumme cleaners to blow up mattresses etc.
Jan 26, 2012 | Dyson DC25 Bagless Upright Vacuum
Is a shop vac supposed to blow while vacuuming? We've had this for several years and I don't recall it blowing air OUT while I am vacuuming.
You should have two ports on the shopvac. One that is basically your vacuum and one you can use as a blower. Your hose will fit on both connectors. So yes, it would both **** and blow. This is called a "blow-through" system.
Jul 30, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
Wap 300 aero. Air release cover.
Contact wwwultimategarage.com. They are a stocking dealer for Wap vacuums, and can probably get the part for you. Wap is one of the best vacuums made & is definitely worth fixing.
Dec 05, 2008 | Wap Cleaning System: SQ 15 Gallon RDF...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
767 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
