Question about Dryers
Dbl 1250 doesnt shut off heating element when done . Hotpoint electric clothes dryer
  • Dryers Master
  • 8,220 Answers
One of the elements has broken and is grounded to chassis.. Unplug the machine and access the innards. Repair the heater.I have some repair photos: HERE
Posted on Feb 02, 2010
Hotpoint Electric clothes dryer
sound like the heating element may need changing
Mar 15, 2014 | Hotpoint Dryers
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
Aug 04, 2012 | Maytag Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
MY NVLR333EVOWW HOT POINT DRYER IS NOT HEATING. HOW CAN I DETERMINE IF IT'S THE HEATING ELEMENT?
I worked on one of these not long ago that was tearing up clothes.. Took some pix
I would say take a look at your element for breaks.
Sep 19, 2011 | Hotpoint NVL333EY Electric Dryer
My hotpoint wdl520 washer dryer is no longer drying my clothes. I still spins but there is no heat for the clothes to dry. Is there a reset button on this model or is it going to be more serious??
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 28, 2010 | Hotpoint Washing Machines
Electrics tripping
Yes, it sounds like the element is broken, and it is easy to replace if you have some mechanical ability.
Jan 28, 2009 | Hotpoint Dryers
How do I find the element that turn up the heat or control the He
On most Hotpoint dryers the element and stats, are located behind a removable metal panel at rear of dryer., unscrew and check the compoents.Plz rate my solution
Thanks.
Dec 20, 2008 | Whirlpool LER5636P Electric Dryer
Hotpoint electric dryer model nvl333eb4cc not dryer clothes. where and how to check for the heating elements or any component that might be at fault
1. Reset a circuit breaker
2. To check the component you have to lift the top of the dryer.
3. all heating component located on the back of the drum.
4. The problem could be one of the safety thermostats or heating element.
5. To replace a heating element is to complicated if you do not have experience.
6. let me know if you going to do this
Nov 29, 2008 | Hotpoint Dryers
Hotpoint aquarius ctd40
most likely, there is a blockage in your exhaust. take it apart and check every inch from your dryer to the outdoors. i clean mine once a year, it keeps the dryer running efficiently. when lint backs up in there, the heat cannot get out and there is a sensor that will shut off the heating element when it gets to a certain temp, so your clothes will take a long time to dry
Oct 27, 2008 | Hotpoint TDC32 Electric Dryer
HotPoint Dryer Model Number NVLR333EVOWW not getting hot
Set the timer one day, later clothes not warm at all, dryer still running and timer had not moved. It has never heated up again. Can you help me figure out the problem? Where all the heating elements, thermostats etc may be. thank you for your help.
Jun 05, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
