It sounds like you are experiencing an issue with your Viking VGSC486-6Q gas oven where the gas continues to flow and the oven continues to heat even after the desired temperature has been reached. This can be a dangerous issue, as it can cause the oven to overheat and potentially start a fire. Here are a few steps you can try to troubleshoot the issue:
Check the oven sensor: The oven sensor is responsible for measuring the temperature inside the oven and sending a signal to the control board to adjust the gas flow and heat as needed. If the sensor is not functioning properly, it can cause the oven to continue heating even after the desired temperature has been reached. You can try cleaning the sensor with a dry cloth and making sure it is securely connected to the control board.
Check the control board: The control board is responsible for receiving the signal from the oven sensor and adjusting the gas flow and heat accordingly. If the control board is faulty, it can cause the oven to continue heating even after the desired temperature has been reached. You can try resetting the control board by unplugging the oven and plugging it back in, or you may need to replace the control board.
Check the gas valve: The gas valve is responsible for regulating the flow of gas to the oven. If the gas valve is faulty, it can cause the oven to continue heating even after the desired temperature has been reached. You can try cleaning the gas valve and making sure it is securely connected, or you may need to replace the gas valve.
If none of these steps help resolve the issue, it may be necessary to have the oven repaired by a professional. It is important to address this issue as soon as possible, as it can be dangerous to use an oven that continues to heat even after the desired temperature has been reached.
The blower should come on after ignition occurs. When the blower comes on first ignition will not be activated as the thermostat signal shows the heat is on. This happens when the blower relay is stuck in the on condition
If it were a furnace, I would say it was a thermo coupler, but on the stove it is called a thermostat. If it goes bad, it will stop the heat after a few minutes, because it can not sent the right signal to the brain. Look at the web site ereplacments and maybe someone has also had this problem with this unit. Parts can be purchased then at the web site. It is what I did for a washer and fridge. Hope this helps.
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
If this range has electric elements in the oven, you may have blown one of the heating elements. Do any of the oven functions work? If you were attempting to BAKE when this occurred, have you attempted to turn on the BROILER to see if it works? If the BROILER still heats up, you may just have a bad heating element. If both features quit working, the problem may be with your Electronic Range Control (ERC) board. Post back with comments and let me know.
