Question about Sony KDS-R60XBR1 60" Projection HDTV
My set has shut down. KDS 55A-200
My set has shut down. when i turn it on the green lite comes on for a second then goes out and a blinking red lite next to it that says 'power' comes on. no picture
  • 69 Answers
Check the lamp and that the fans turn
Posted on Feb 07, 2010
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
W KDS-R50XBR1 50 in. HDTV Television standby light blinks red 3 times
Something you might want to look at:http://sites.google.com/site/sonylcdrptvproblems/lamp-overheating-issue
Apr 06, 2012 | Sony KDS-R50XBR1 50" HDTV
Green power light blinks, and TV comes on, and goes out, and power light goes red
Sounds like a problem with the power supply. After it shuts off do any other lights blink, apart from power LED turning red? Please provide this info as it is a self-diagnostic code that will help identify the problem.
Sep 16, 2011 | Sony KDS-55A3000 55" HDTV
Out of the box green light comes on and blinks for 10 to 15 seconds, blue screen on television appears for a few seconds then goes black and red light blinks and nothing happens
Only get Welcome screen and green blinking lite. Then shuts off. Buttons locked out also. Need to get software update V41C-11.3 Mitsubishi-tv.com. Go to support then software update. It will ask for model, ser. First and Last name and E-mail. download. http://www.avsforum.com/avs-vb/showthread.php?p=19844230
Has a link about 1/3 way down that will go right to the download. Very helpful.
May 28, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
I have a Sony KDS-R50XBR1. it worked fine last night, this morning however, it did not come on at all. it blinks green for awhile, then blinks red continuesly. what is wrong? please help.
The red blinks are a diagnostic tool. If you search this site for KDS-R50XBR1 you will see several problems and the area to look in to. the red blinks should be followed by a three second pause and then repeat. Just count the blinks after the pause and you should have a better idea of what is wrong. The service manual goes all the way up to ten blinks.
Feb 08, 2011 | Sony KDS-R50XBR1 50" HDTV
The screen in black, but I get sound. Just replaced the bulb about 5 months ago. There is a green light that flashes, but not the red light. a couple of seconds after turning on the TV, I could hear...
Outside of the lamp failing, the main exhaust fan on the Left side facing the back of the set is common to fail, the set shuts down. But when this happen it always causes the red led on the front of the set to blink a code. If the green led continues to blink, I would inspect the lamp, if appears to be ok, reinstall it making sure that the inner door latch for the lamp is secure and tight.
When looking at the lamp, pay attention to the the bottom of the lamp stem where the bubble is. If you see a discolored, bulged out area on the bubble, the lamp is bad. I have seen this happen even on new lamps from Sony.
I hope this helps,
Skyassoc
Dec 10, 2010 | Sony KDS-55A2020 55" Television
When turned on green light flashes, then red flashes, no pic or sound
If your lamp is more than a few years old, I'd start there. The second issue has to do with fans. They should all run when the projector is turned on. Any one of them that won't come up to speed will shut down the unit. If the air flow is obstructed by dust, the thermal fuse could have blown.
Knowing the red blink code pattern will help to narrow down the issue, Google Sony (your model number here) blink codes and you should get info on what the blink patterns mean.
Once you determine what part is bad, google the part and you should come up with suppliers that will sell you what you need.
If your color is turning green, yellow or blue, you may have an optical block issue that you're not likely to get parts for on the open market.
Jul 28, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Oct 15, 2008 | Philips 42FD9932 42 in. Plasma Television
Sony KDS-R60XBR1 60" Projection HDTV Logo
148 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
