Question about Whirlpool Calypso GVW9959K Top Load Washer
How many gallons of water does the calypso use
  • 572 Answers
Not much it barely fills. energy star unit
Posted on Feb 06, 2010
I have standing water in my calypso washing machine and i want to be able to drain it without have to do with a bucket or shop vac
On that Calypso their is going to be some lint build up in the drain buildup in the drain pump causing it not to drain. If you set the drain/spin cycle about 20 times eventually the water should drain. Thier is no real way to get the water out without bailing it or vacuuming it out.When all the water finally out can take apart draim pump and remove lint build up.
Aug 11, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
How much water does a top load Calypso use. Does it fill up or use minimal amount of water?
Not sure exactly the amount of water but they fill to about the bottom of the door gasket
Feb 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water leak at the bottom?
you may have hose leak, or you may need to replace the water pump.. also check the hoses from the water supply lines. water may be running down behind the hoses
Oct 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
OB code plus water leakage
yes its most likely a defective pump...but do some homework,,,calypso was recall a couple of years ago...start a this site servicematter.com
Jan 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Warer stop on fill up
  1. try to recycle the level control hi and low. Try the hot and cold to try and get more water in the unit. JOHN-LA.
Aug 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer
When changing a pressure switch on a calypso you have to be sure the tub is empty. blow air into the hose to clear, also observe for moisture where the hose connects to the tube for a pin hole leak in the tube.
Aug 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washing machine
WP HAS HAD A ON GOING ISSUE WITH THIS THAT IS THE REASON WHY THEY REDIGNED THE DRAIN PUMP. YOU NEED TO 1ST DRAIN OUT AS MUCH WATER MANUALLY AS YOU CAN THEN DISCONNECT ALL YOUR HOSES FROM WALL TAKE THE WM OUTSIDE TO DRAIN THE OTHER 3 GALLONS OF WATER YOU CANNOT SEE. TURN THE MACHINE ON ITS BACK THEN USING A 5/16 NUT DRIVER REMOVE 4 SCREWS ON THE BOTTOM PANEL. REMOVE PANEL AND YOUR DRAIN MTR IN ASSESSIBLE. THE PART CAN BE ORDERED AT WWW.REPAIRCLINIC.COM
May 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
FL code won't go away
yes, replace the drain pump. it will come with a pump and motor. it wont look the same as the one you have but hooks up the same and it will solve your problem
Nov 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
