Question about Agfa SnapScan 1212u Flatbed Scanner
A Communication Problem Occurred. Open log file
I get this message when I click on to my scanner A Communication Problem Occurred. Open log file to find out more. I cant find the log file have looked in programs file (Agfa) any help appreciated
  • Anonymous Jul 12, 2008
    I have had exactly the same problem, your solution using wnaspi32.dll - (my copy came from Mcfee Total Protection Suite 2007) works brilliantly, Thanks!
My scanner Agfa Snapscan 1212u can "scanpreview" an image but when I try to save/scan it, a message tells me that "an unexpected error has occured. The application is unable to recover and will close". I have windows xp and the latest drivers
Posted on Jun 25, 2009
  • 3 Answers
Winaspi32 tif works great also with 1212p with on/off button but you need also editing cnfgvars.txt in scanwise folder increasing values for:
after all, if still doesn't work try to change compatibilty mode in scanwise.exe properties to windows 2k mode.
bye, massi+
Posted on Aug 06, 2008
Nobody doesnt help me, but with this helpful information everithing working best!!!
Posted on Jul 06, 2008
Thanks a lot Guest for your solution !
I had the same problem and your tips with winaspi32.dll solved my problem !
Posted on May 16, 2008
Have seen following solution:
Copy wnaspi32.dll (from nero) in %windir%\system32.
Open cnfgvars.txt (from Scanwise folder)
Change /USE_ASPI from "0" to "1"
... Good Luck
By the way : Problem is comnig from usb 2.0 port
Try following :
Install Scanwiise (Scanner has to be unplugged)
Plug in the scanner
Install the driver
Posted on Apr 20, 2008
There is a textfile named scanwise in the directory of scanwise (version 2.0). There could you find some more information about your communication problem. Sometimes the info is a little bit short, but maybe this info can help you to get additional support.
Posted on Mar 13, 2008
Hi, i am having a problem trying to remoove yohoo messenger from add and remove programs, i get a message.,.could not open install.log file. my computer is now starting to low down.. confussed, ...
1) select Start->Run
2) click Browse button
3) find unwise.exe in Yahoo! install folder (usually C:\Program Files\Yahoo!\Messenger\unwise.exe), click OK in 'Browse' window
4) after that you should see in Run window the following:
"C:\Program Files\Yahoo!\Messenger\unwise.exe"
5) edit this line, so it looks like:
"C:\Program Files\Yahoo!\Messenger\unwise.exe" install.log
(after "the path" put the space and type install.log)
6) click OK in Run window
That should uninstall yahoo messenger.
Mar 11, 2011 | Computers & Internet
The error message "an error
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Jan 28, 2011 | Panasonic Computers & Internet
Cannot open Outlook Express after compacting the files...
Thanks Everyone.. I fixed it with ther help of a great person.. DONT BUY THE PROGRAMS THAT CLAIM TO FIX ... All I did was the following:
Rename the Folders.dbx file:
  1. Click Start, point to Search, and then click Files or Folders.
  2. In the File name etc type, type folders.dbx.
  3. In the Look In box, click your primary hard disk (usually drive C), and then click Search.
  4. Right-click the identified Folders.dbx file or files, and then click Rename.
  5. Type folders.old, and then click OK.
  6. Start Outlook Express. This creates a new Folders.dbx file automatically.
Just change .dbx to .old That is all that was required.. RENAME!!! Not buying programs that dont work...
When I opened it the folders were a little messy.. but that is fine when you consider I felt that I had lost the program and all Emails stored. Problem only occurred after a suggested compacting of emails by the program.
Errorwiz DID NOT FIX
Good luck and I hope it works for you..
Oct 02, 2009 | Microsoft Outlook Express
Epson TX800FW
u have to tourn on file and printer sharing on yours printer, open printer and faxes find yuor printer, right click it and then click propetys inn the properys meny click sharing then turn on file and printer sharing.
Sep 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I lost all my logs and cannot get or send a fax when i try to do anything, i get the message"the following error occurred when attempting to open a folder, call failed one or more files for that phonebook...
This error indicates corruption of data, would I would suggest is to backup your data files immediately, the biggest mistake many do is by copying files while WinFax is open. Make sure WinFax is closed, and the WinFax Service is stopped when you copy or move data around. See Rebuilding phonebooks here:
Jun 24, 2009 | Symantec WinFax Pro for PC
I use frontpage 2003 to edit my site( I am getting an error message on my page called ''Miscellanous'' that reads: An error has occurred accessing windows share point server...
Hi..seems you are trying to edit SharePoint Portal sites using the same using sharepoint designer and with proper administrator credentials..(usually it prompts when you connect to server using a client machine)...All changes done to the application files are then committed on the server- end and will work absolutey fine../
warm regards.
May 06, 2009 | Computers & Internet
Open the log file
Looks like you've confimed that there's an issue with the scanner (which might be up to 17 years old) so it may be time to let go. I see from the specs that the scanner also supports Windows, so maybe before you send it to that great recycle bin in the sky, you give it one more shot at life, by connectiong it to a Windows machine.
Jan 09, 2018 | Agfa SnapScan E25 Flatbed Scanner
I cant scan!
Resolution : I
1 Scan using Windows Fax and Scan
Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  • Click New scan .
  • Click File , and then click Scan .
  • Option two: Scan using Paint
    1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
    2. Click Paint .
    3. Click File , and then click From Scanner or Camera .
    4. Click Scan .
    II nd issue :
    Problem :
    'An error occurred while communicating with scanning device' Message Displays in Windows Vista When Scanning
    Then refer to
    Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
    Agfa SnapScan 1212u Flatbed Scanner Logo
    934 people viewed this question
    Top Agfa Office Equipment & Supplies Experts
    Chris Larocque
    Pierre Legault
    Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
