Question about PC Chips P23G Motherboard
I imaged a vista 32 bit from a laptop with Ghost and restored it to a maxtor serial ata HD and installed to P23G MB. It will not boot, I get a BSOD with instruction to remove any newly installed HD or HD controllers. I have tried VISTA repair process w/ no success. I installed same hardrive in another system and it boots normally. I have cleared CMOS and restored defaults to BIOS, I hace tried to boot to safe mode but I keep getting the BSOD. Please advise
  • 2 more comments
  • martyg4 Feb 02, 2010
    Except as I explained in my post The same harddrive in another system boot flawlessly!!!
    Anybody else like to address this issue
    someone with experience please
  • martyg4 Feb 03, 2010
    Finally someone who understands-thank you
    It seems I an having an infrastructure meltdown here at home I will try your sggestion as soon as I can, and let you know
  • 4,281 Answers
It is because old driver are not camptible with your computer for that you need to connect harddrive where you are able to enter in windows then uninstall all driver and software then try with your computer.
Also go to start menu ->run then type in run "chkdsk /r" then press "y" then restart computer then it fix eror on harddrive .
Then connect yopur harddrive to your computer where you get blue screen of death BSOD error.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 03, 2010
  • 644 Answers
Being as the hard drive has been booted up in another pc you know the hard drive is fine and ghost image is not corrupt, so that is not the problem, i suggest checking the bios again and if the board has got a primary ide socket to check that the sata is the primary boot, it could also be worth checking the sata cable, maybe using the cable out of the other pc you tested it on. As it worked in another mechine suggests that it could the hardrive controller circuits on the mother board maybe faulty, have you tested another hardrive to see if you get the same problem? post back your results and hopfully we can remedy this. cheers.
Posted on Feb 02, 2010
  • 542 Answers
This is due to you have restored the different ghost image for different hardware system. You need to install OS freshly and then create ghost image for future restoration purpose.
Revert back for more assistance.
  • Rajesh Pai
    Rajesh Pai Feb 02, 2010
    Then may be problem with HD controller. check and rectify the same. If possible go to safe mode and install driver for HD controller.
  • Rajesh Pai
    Rajesh Pai Feb 13, 2010
    I didn't received any update on the solution provided. Hope your problem got resolved.
    Revert back for more assistance and give your valuable feedback/rating for the solution provided.
    Thank you for using Fixya.
    President:
  • 1,188 Answers
You cannot use a ghost image file on a second motherboard. This is how it works in case of Windows XP and newer. It will work in case of Win 98, however.
You need to install Vista from scratch on the new PC.
Trying to install vista 32 bit on my Gateway DX 4720-03.Vista won't install because it can't see Hard drive. How do i disable ahci or sata mode in the bios or is there a work around to install Vista32.
Vista will have the drivers necessary to identify SATA/AHCI controllers, built-in by default. It would not be necessary to turn the AHCI mode 'off' or to 'ATA' mode (unless you get a 7B or inaccessible boot device BSOD). Check if your system has a RAID configuration, in which case there may be a 3rd party supplied RAID driver that you need to install first. Also, check if the HDD cables are connected properly & the HDD is detected in the BIOS (System setup screen) first.
Mar 16, 2010 | Gateway DX4720-03 PC Desktop
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Jan 21, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
I want to change the HD from 40Gb to one with more capacity but I tried to make a ghost image in a 120GB and 160GB HD but the bios don't recognize it and only can see in the screen a simbol _ flashing.
Not sure which software you are using for making the ghost image. Lets say its "Acronis".
First, you will need an USB hard disk drive to store the image on.
Next, run the boot cd and choose backup.
Send it to the hdd.
If it was successful, remove / replace your hdd.
Run the boot cd again but now choose "Restore". Locate your image and then wait.
Hope this helps you. Norton Ghost is a bit different.
Oct 20, 2009 | HP Compaq nx5000 Notebook
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Get windows vista home premium
You can run a 32 bit technology OS on a 64 bit technology platform.
It will run pretty fast.
You just can't run a 64 bit technology OS on a 32 bit technology platform, though the 64 bit OS is recommended on a 64 bit platform.
Love your brother, he did you no wrong.
Mar 30, 2009 | Dell 24x CD±RW/DVD Serial ATA Internal...
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
System restore
press ALT key and keep tapping F10 key as soon as you switch on the laptop.. keep tapping till you get to the screen where it says acer system restore
Sep 25, 2008 | Acer Computers & Internet
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
Cannot install vista - BSOD
the processor is core 2 quad 2.4 ghz, and as far as i know it does support 64 bt os. also bios is updated to latest from intel site using flash drive. but there were no mentions in the bios about using 32 or 64 bit os
Jul 20, 2008 | Intel DG31PR Motherboard
BSOD on XP64 fresh install
Here is an picture of the Blue screen I am getting
A larger version of the image can be seen here:
http://www.pjbproductions.com/bsod.jpg
it's a bit out of focus but should be ledgible. I don't think it's seeing it in the BIOS either. I will confirm tonight when I get home from work.
Apr 08, 2008 | ASUS P5LD2-VM Motherboard
PC Chips P23G Motherboard Logo
70 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
