Question about Sigma Super Telephoto 600mm f/8.0 Mirror (Reflex) Manual Focus Lens for Nikon AI and AF
I HAVE A SIGMA 600MM MIRROR LENS , WITH A
I HAVE A SIGMA 600MM MIRROR LENS , WITH A SLIDE IN AND OUTS DEVICE , THAT HOLDS A SMALL FILTER,AND INSERTS INTO THE SMALL END OF THE LENS , I'M TOLD THERE ARE 5 OTHERS, IN THE SET, VARIOUS COLOURS , BUT IVE SEARCHED THE INTERNET FOR HOURS , ALL I CAN FIND IS INFORMATION ON A SET OF 3.5MM DROP IN FILTERS, BUT THE FILTER THAT IS IN MY LENS , IS SMALLER THAN 3.5MM, CAN ANYONE PLEASE TELL ME WHAT ARE THESE FILTERS CALLED ,WHAT IS THE EXACT SIZE I NEED ,AND WHERE I WILL FIND THEM ??
  • 146 Answers
The nominal filter size of the Sigma 600mm F8 Mirror lens is 30.5mm(Rear).
The actual filter has a rear screw thread measured across that is approx 22mm.
Does this look like what you have?
If you look for Sigma 600mm mirror filters on the web you may find some.
As you can see by the photo the filters are mainly for film use.
Posted on Feb 02, 2010
Which lens fit nikon d5001
To the best of my knowledge, most, if not all, Sigma lenses fit most cameras that use interchangeable lenses with the appropriate adapter. As I recall, Sigma uses a bayonet mount and adapters are available for many name brand cameras. For example, I have a Nikon and my Sigma 600mm came with an adapter for a Canon. All I had to do was order a Nikon adapter. If you're not sure, you might want to check with a local camera store to confirm which adapter you need.
Jun 17, 2014 | Sigma Super Telephoto 600mm f/8.0 Mirror...
I would like to use my Sigma 600 Mirror lense on Nikon M80 digital camara body lense was used on a Pentax Super A camara before can it fit
Sorry, no. If it fit onto a Pentax camera then the lens has a Pentax mount. The Nikon (I assume you mean the D80 digital camera, or perhaps the N80 film camera) has a Nikon mount. Since the Nikon mount has a deeper flange distance than the Pentax mount, there are no adapters available to allow you to fit a Pentax-mount lens onto a Nikon camera.
Jan 14, 2013 | Sigma Super Telephoto 600mm f/8.0 Mirror...
I have a sigma 600mm k mount lens that I would like to use on a nikon 3100, is there a adapter available?
No. The Nikon F mount has a longer flange focal length than the Pentax K. What this means is that a lens adapter to fit a K mount lens onto a F mount body would have to have a negative thickness, which is a bit difficult to build with current technology.
Adapters going the other way are possible and available.
Feb 16, 2012 | Sigma Super Telephoto 600mm f/8.0 Mirror...
How do you remove mould from the mirrors of a 600mm Sigma Mirror Lens.
You should send it to Sigma for repair.
Their contact information is right here:
http://www.sigmaphoto.com/contactus
Mar 19, 2011 | Sigma Cameras
Is there any method to stop-down the sigma 600 mirror lens?
This kind of lens design does not accommodate itself easily to a diaphragm type aperture control, and it usually already has a small aperture fully open anyway, so there is seldom much done to allow "stopping down". Some lenses of this type have built in filters that can be dialled in by a knob, including neutral density filters which have the effect of adding a stop or two of "aperture" control, although they don't actually stop down the aperture as such. The neutral density filter settings will be labelled X2 and X4, which is the multiplier for the base F-stop number, i.e. f8 X2 = f16, f8 X4 = f32.
If there are no such filters built in, you can usually add them to the rear element of the lens, clearance permitting. They are added to the rear because this requires a much smaller, and cheaper, filter than would be required to cover the front element.
Dec 26, 2010 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Sigma 600mm mirror lens
No but you can get a converter for it
Aug 30, 2009 | Sigma Super Telephoto 600mm f/8.0 Mirror...
I was given a sigma mirror-telephoto lens (600mm) It says right on it that it is for a Cannon. I have Cannon Rebel xt and cant figure out how to attach it. Does it work with a Rebel? And if so how? Do I...
You need a T-mount ($30) for a Canon on E-bay or a big camera store. There is NO connections to the camera body, so you have to turn off auto focus and go to "Auto" mode (the shutter speed will change) as the lens is fixed at F8. The mirrors give very little depth of field, 4 or 5 feet when far away but everything in back is a blur of circles. At F8 the shutter speed can go slow and at 600mm you may need a tripod.
Jul 18, 2009 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Sigma 6oomm mirror front lens removal
there is a locking ring you have to remove and then the front optic may fall out if it sticks you may need to heat up the barrel that might work
Jan 09, 2009 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Sigma 600mm mirror lens internal part discounnected
There is a ring you must remove then you will have to soften the silocon we use aceton but you must be very carefull DONOT lever out the elemet just turn over the lens and bang it on the table a few times and the front element will fallout with luck
Jan 04, 2009 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Sigma 600mm lens mount
You may be able to find a Konica toMinolta or Konica to M42 adaptor. Some adaptors are available...some aren't; it depends upon the film plane dist. and mount diameter. For instance you can get a Nikon to Canon adaptor, you can't get a Canon to Nikon adaptor. Email KonicaMinolta and ask them.
Jan 18, 2008 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Sigma Super Telephoto 600mm f/8.0 Mirror (Reflex) Manual Focus Lens for Nikon AI and AF Logo
1,471 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
