Question about Agri-Fab Agri - Fab Snow Blower - 42"
CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE - RAISE REAR UP AND WHEELS DO - AUGER WORKS IT JUST WON'T MOVE
  • Anonymous Mar 15, 2014
    model 536.881400
    Problem Solver:
  • 16 Answers
Well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
Posted on Feb 04, 2010
    Scholar:
  • 126 Answers
The first thing to check is the cable adjustment. Follow your manual to get the correct gap. After that, the next most likely cause is your friction disk is worn out. Here's a youtube video showing how to replace it (different model snowblower, but the principal is the same).
HOW TO Replace The Friction Disc on Murray Noma Craftsman Snowblowers...
One thing Donnyboy73 didn't mention is to run the blower out of gas before you put it into the service position (IE standing upright on the auger housing).
If the friction disk was worn out, it's best to go ahead and check (and replace if necessary) both belts. Usually they will be worn when the friction disk is worn. Personally I recommend using OEM parts; especially when it comes to belts.
Posted on May 21, 2014
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
Dec 03, 2016 | Garden
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Need to decrease Wheel Speed. Blower works well except for this. Keeps plugging up, because it moves to fast.
part of the drive plate. Lift the machine up on it's auger and take the bottom cover off. with the speed lever at its slowest see if the little friction wheel moving linkage can be adjusted so the friction wheel gets as close to the middle of the drive plate as possible. Sometimes it's just an adjustment on the shifter arm.
http://www.ereplacementparts.com/poulan-pp11530es-96192001901-snow-thrower-parts-c-16962_168114_294540.html?page=4
loosen and adjust item 20 and 25
Dec 14, 2015 | Garden
Service manual for craftsman 24" snow thrower
the only thing holding in the auger is the block bearings on each side (three bolts in each side) the center drive is hex splined and should come right out ,unless its bent as well.
if you call 1800sears parts with model and serial number they can get you a new auger assmebly mailed right to your door
Feb 24, 2015 | Garden
Snow thrower auger won't turn
One of the grip levers should engage a clutch that controls the augers. The other grip lever should engage a clutch to drive the wheels. Figure out which is which, and track the linkage from that lever down to the gearbox between the augers and the impeller. See if there's an adjustment you can make there.
If not... the gearbox may be damaged, possibly by hitting a solid object with hardened bolts in the place of your shear pins. ALWAYS use soft shear pins!
Feb 16, 2014 | Craftsman 24" 179cc Dual-Stage Snow Blower...
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
Where is the auger sheer bolt
Figure 9 on Page 11 of the manual (linked below) shows the location of the auger shear pins. Do NOT substitute bolts for shear pins!
http://www.searspartsdirect.com/partsdirect/user-manuals/8227/536881800-Craftsman-Parts-SNOWTHROWER,+GAS-manual?pathRender=fromManualTabPage
Feb 11, 2013 | Craftsman Sears Snow Thrower Manual Model...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Agri-Fab Agri - Fab Snow Blower - 42" Logo
2,475 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
