Question about HP Pavilion ze5185 Notebook
Power problem I seems as though the power pin on the motherboard on my ze5185 is 'broken'. We can't get AC power at all...only battery power. Is this something that can be fixed or should we just replace the motherboard? Is replacing a motherboard as easy as just taking out the old one and putting in a new one?
  • 1 more comment
  • Tall ndn guy Jun 05, 2008
    The power port looks like it's been smashed? What is the part number for a new motherboard?
  • danbandomir Nov 18, 2008
    I have the same problem with the power connector, I have the laptop apart in 100 pcs. How can I get the power connector part?
  • PC crazy Dec 15, 2008
    My pin broke off after the adapter was overheated and when removed the plug melted around then pin and it broke off.
    President:
  • 4,402 Answers
Can you take a volt meter and test the ac adapter?, you can check the bottom of the power jack on the motherboard see if it has a solder joints are cracked.
good luck
please mark the post with a fixya
Posted on Feb 19, 2008
    Sergeant:
  • 406 Answers
If you are sure about Power pin is broken an expert technician can assist to get it fixed [instead of replacing the mother board]
Best Regards
Rafique
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
I have sony vgh-cr590 laptop. For some reason there is no power. The AC adapter has the green light but I am not sure there is power to the computer. The battery will alos not work. I am computer savy...
sounds like a issue with your new ac adapter, or you can be dealing with a broken power pin, This is very common in Laptops, The Power Pin is a connection between your Ac adapter and the motherboard, often this pin is accidently broken causing no contact between the power port and the mother board causing your power issue. If it is the power pin, it will more than likely need professorial work, because the pin needs to be re-soldered back onto the mother board. Total cost for the power pin averages about 40 bucks and most techs will charge around 200 for the labor.
Hope this helps, take care and have a great week.
May 26, 2011 | Sony Vaio VGN CR590 Laptop Universal AC...
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
I am getting an error msg Invalid AC adapter on my Dell Inspiration 1525 laptop. For Bootup. The ac adapter indicator light is on. The battery does not seem to be charging it is at 82 %. And seem to be...
If the system is not identifying the AC adapter, then the battery charger circuit is disabled. So replacing the battery will not resolve the issue. If the sensing pin in the center of the power connection to the portable is bent or broken, then replace the adapter. Also try a known good Dell Branded AC adapter, if issue still occurs, it will require an motherboard.
Jun 20, 2010 | Dell Inspiron 1501 Notebook
It wont power up
make sure you plug the battery properly or it has ha charge, just to try or check if its in the battery, first remove your battery and plug your ac power cord into your laptop and try to open it, if i work, your battery might be drained or don't have a charge, or you have to replace your battery.
May 10, 2010 | HP Pavilion ze5185 Notebook
The input jack to recharge my battery has bad connection
YES. This seems to be a common problem. I am just researching doing this with my Gateway.
Things to remember.
1) Shops which do this have the parts to do it right.
2) You might get a better price if you remove the motherboard and just send the mother board for soldering.
3) AND THIS IS VITAL. Some jacks are soldered in such that power is delivered to both sides of the motherboard using a copper sleeve. If you try this at home, you might not get the connection right.
Sorry for the bad news - talk to a shop which can do the repair. I saw prices of $90-$130 for everything except the shipping of course. . .
Mar 16, 2010 | HP Pavilion ze5185 Notebook
Toshiba plug-in ac adapter LCDlight flashing and wont boot up
It may be that you need a new, (Or good condition used), motherboard. You may not.
The problem could be the DC Power Jack. The DC Power Jack is small, and the body is made of plastic. Sometimes there is a metal shell around the plastic body. (The jack is a rectangular shape, and is just a little larger, than the outside portion of that AC adapter plug!)
This is an example of a DC Power jack for a Toshiba Satellite a215-s5807,
http://www.notebookworks.net/ProductDetails.asp?ProductCode=NBW52-0133
As you know there is a metal pin in the center, and at the back of the round hole, there are flat metal contacts.
Let me explain the construction of a DC Power Jack, and how it's mounted to a motherboard. This all has relevance to the solution.
Your laptop uses DC electricity. (The AC adapter converts AC to DC. Your laptop battery, and a flashlight battery, are examples of stored DC electricity)
DC uses a Positive connection, and a Negative connection. The metal pin in the center is Positive. The flat metal strips at the back are Negative.
That laptop DC Power Jack has metal prongs, that come out of the plastic body. One prong, (Or pin), connects to the Positive metal round pin, in the center of the jack.
There may be one, or two prongs, (Or pins), that come out of the plastic body, and connect to the Negative side of the jack. (Flat metal strips)
These prongs go down through holes in the motherboard, and are soldered on.
With the AC adapter plugged in, an accidental bump on the plug itself, could break the body of the jack, or break solder joints that hold the jack to the motherboard.
AC adapter removed, and battery removed. Use a NON-metallic object, and see if you can make the center pin of the jack move. See if the entire jack itself seems to move.
A.If the center pin moves, you have a broken DC Power Jack.
B.If the entire jack moves, you have cracked solder joints. (Broken)
Replacement of the DC Power Jack for A.
Re-solder the solder joint/s for B.
Cost of replacing a jack at a reputable computer repair shop? $90 to $150
Cost of re-soldering solder joints? $50 to $90
Cost of replacing the motherboard?
$250 on up.
If you are a skilled person with the correct tools, it is feasible for you to replace the jack, or re-solder the solder joints.
It is also feasible that you yourself, could replace the motherboard.
Some laptops have a poor motherboard design, for where the DC Power Jack is mounted to the motherboard.
Crude explanation would be, that the main body of the motherboard is a 1 foot square. Then a 2 inch square comes out of the side of the main body.
The DC Power Jack is mounted to that 2 inch square. From accidental bumping, OR just normal usage of inserting, and removing the AC adapter plug, this 2 inch square can crack away from the main body.
This, of course would require a motherboard replacement.
Disassembly instructions for a Satellite A200 and A205 Series laptops. Very close to the A215 Series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
(Don't forget to buy, and use a cheap ESD wrist strap, to prevent static shock to the delicate hardware components, inside your laptop. Average cost is $7)
Aug 04, 2009 | Computers & Internet
Gateway lap top is not getting any power, the power light is off any solutions?
1. First of all, go to http://is.gd/scG3/gateway/support and enter your serial number to make sure you still have warranty (just in case you need to order parts or send in your lappy) 2. You can open a chat window with gateway to describe to them your issue 3. Possibly order a new part, or fix the solution via gateway support.
ps. My suggestion is either a bad power cable, or bad battery. They will probably send you a new one of either for free if you still have time left on your warranty. Otherwise you'll have to pay, but it'll fix the issue. If you have any further questions, reply to turner.micah@gmail.com.
Apr 13, 2009 | Gateway Computers & Internet
The computer does not seem to be charging up
I am a Dell Certified System Engineer(DCSE)
try taking out tthe battery and then try powering the system only on ac adapter connected
if it doesn't power on only on the ac adapter make sure that the port on the system where you plug in the ac adapter for any kind of bent or broken pins
if the port is ok then get your ac adapter replaced.
Jun 10, 2008 | HP Compaq nx9020 Notebook
HP ZE5185 Clock Problem
they are all rechargable you need to keep sufficient charge in battery.imagine if you didnt charge your mobile phone for 6mth.
Apr 09, 2008 | HP Pavilion ze5185 Notebook
HP Pavilion ze5185 Notebook Logo
138 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
