A carriage jam error keeps showing on the printer screen and the inks seem to be jammed. They make noise as if to want to print however the same error notice keeps appearing. Before this when printing several sheets were printed with smuges on them. What can I do to rectify this situation?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please follow these step by step instructions to remove the carriage jam error:
1) With the Printer power on open the door so that print heads move to the center.
2) Unplug the printer, kindly make sure to unplug don’t turn it off.
3) Open the back door.
4) Look inside the back left side for a small black gear (About the size of a quarter)
5) Spin the gear with a screw driver (I'm pretty sure I spun it clockwise). Spin it and watch the inside of the printer where the print heads park. You should see a tray move out that has four rubber blue rectangles on it on the right side of the unit (this is where the print heads park when the unit is not printing).
6) Keep spinning the gear until the plate moves all the way forward.
7) Grab the plate and try moving it forward more.
8) Put the back on and close the top.
9) Turn the unit back on.
10) Open the top again
11) Unplug the unit again. (Don't turn off, just unplug!)
12) Grab the tray, from step 5, and slide it all the way forward and all the way back multiple times.
13) Make sure that the print heads slide left to right smoothly
14) Remove ink cart's and clean the contacts with bottled water and a q-tip. LET DRY BEFORE REINSTALLING!!!
15) Remove print heads and clean contacts with bottled water and q-tip. LET DRY BEFORE REINSTALLING!!!
16) Clean the inside of the printer with a soft dry cloth, use a slightly damp, with bottled water, lint free cloth (Glasses cleaning cloth works well) and wipe off the rollers in the front and back of the unit. See HP's cruddy support site for details on this step.
17) Hold down #7 (reprimes the printheads with ink) and plug in the unit
You can also check this link on how to remove the carriage jam. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 02, 2010
My brother printer mfc-j415w keeps giving me an error message which says paper jammed, I removed all paper and bits of debris found in between the rollers but it still keeps giving me the same error m
there will be paper to the side of the printer which is stopping the carriage from travelling fully which will also be why it makes a noise.
If its to the right of the carriage, start printer and when carriage starts to move pull the power lead, you'll be able to move the carriage out of the way and look in with a torch to find the paper or foreign object. Just remove it and restart the printer and everything will be normal.
Please indicate if it fixed your problem here.
If you need ink for this printer go to our site:
http://www.the-inkstore.co.uk
Jan 29, 2013 | Office Equipment & Supplies
THe screen is showing ERROR...Carriage jam open
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do a clear a carriage jam on a hp6210 printer
My HP6210 printer had the same problem. The carriage would make a lot of noise going back and forth and I got the carriage jam error message. Using a flashlight, I found an incredible amount of ink (mainly black ink) underneath the mechaism which clears the ink off the print cartridges. I throughly cleaned the internal components and it works again.
Mar 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Documents are printing slanted on page
It sounds like need some technical maintenance and at that point you have two options.. take it to a service center, or buy another printer (or if whithin warranty talk to HP about your problem, your attempts to fix it and possibly get it replaced). sounds like a component inside your printer may be either not working properly or there's something inside keeping the rolling componentes from keeping the page straight as it goes through your printer.
It does not sound like a driver problem...
btw.. did you mean carriage jam or cartridge jam??
if it was carriage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00054450&lc=en&dlc=en&cc=us&rule=8331&product=303753
if it is a cartridge error try check the following:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&lc=en&dlc=en&cc=us&rule=8331&product=303753
Nov 26, 2008 | HP Photosmart 2410 All-In-One InkJet...
My printer will not load and the window says the carriage is jammed. It is an HP Officejet 7410 All-in- one. It first had the message Paper jam and after I opened it and there was no paper jam I...
1. Check if there are broken parts inside the printer-carriage area
2. Turn the printer on and off
3. Clear any paper jam by opening the rear access door at the back of the printer. If there are no paper jams. Clean the rubber rollers with a lint free cloth that is moist with water
4. Make sure that the carriage can move freely
5. Remove then reinstall the ink cartridges
6. Make sure that the control-panel faceplate is correctly installed
7. Plug the printer directly to the wall outlet
8. Perform a partial reset on the printer.
a. Unplug the power cord from the All in One
b. Press and hold # and 3 while plugging the power cord
c. Do not release the two buttons unless the printer would say reset
9. Try to print
10. If this would not resolve your issue then the printer sensor is already defective.
Aug 06, 2008 | HP Office Equipment & Supplies
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Carriage jam
My wife had replaced bith ink cartridges and the carriage was also jammed! what she did was helped the cartridge carrier up some and it finally clicked in!!
Jan 23, 2008 | HP PSC 1610v All-in-One Printer
21 people viewed this question
jasbo
jasbo
