Question about Magellan Maestro 3250 GPS
This is the second time in 2 years this has happened. When I turn on the unit I get a 'Warning - low battery" message, even though I am plugged into the car via the cigarette lighter power cord. (I have checked the power cord and it is supplying current to the unit). If I press YES to continue, I go into a loop where the unit performs as usual, except it flips back and forth between the battery warning message and the normal GPS screen. I sent it back to Magellan the first time, but apparantly they didn't make a permanent fix. Any suggestions? Steven Tomaryn
  • steventomary Feb 02, 2010
    As I mentioned in my original post, I already checked the charger cord! This appears to be a sealed unit. Is there any way to check the battery? And/or replace it?
    Steven
    New Friend:
  • 125 Answers
If it shows on the indicator that you are in fact getting power to the GPS, you might want to open it and check the battery connections. If you need to replace the battery it is a:
t0052 Li-ion battery 3.7volts and 1100mAh
Posted on Jul 30, 2010
  • 10,515 Answers
Does it shut off when your using it on the PC? If not, there is something not right with the car adapter. Also, just because it was plugged into the car adapter does not mean it was charging. Many cars will turn off the cigarette/accessory jack when the ignition is off or shut off after a short while to protect the car's battery from being run down. Try hooking it up the the PC overnight and leave the PC on. In the morning, disconnect the GPS and try using it. Does it still shut off? If so, the internal battery may be bad. If it works and doesn't shut down, you have a problem with it not charging in the car and the adapter may be bad.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
    Genius:
  • 1,341 Answers
I would suggest you check the charger and get a test meter and read the voltage reading at its end.Sometimes over wear and tear the wire inside the charger snaps (or is on border of snapping which then will give you some reading on the tester when you play with the wire charger) and cause an open connection.Hope this helps else you have a bigger problem with the navigation itself.
Posted on Feb 02, 2010
Washer fluid reservoir pump
Maybe its a bad sensor is bad? try replacing that
Jan 10, 2014 | GMC Cars & Trucks
Hi, My rev counter has suddenly stoped working after i diconected my battery. Also the low oil warning light is flashing constantly even though there is sufficiant oil. Help please! Regards Stan. P.S. The...
Hi Stan, are you didn.t connect back battery in wrong way? If the battery terminals has being turned around only for a second you might damage lots of electronic units in the car.If not the problem seems happened incidentaly.Any way the signal for the rev counter coming from the ECM. Oil level lamp can be a sensor
May 01, 2010 | 1995 Volkswagen Golf
The laptop can not be turned on though it is plugged in
Usually such old laptops show problems to turn on if the battery has a loose contact or if its completely blacked out. Looks like you have to change the battery and then keep the lap on charging mode for 2 hrs and then switch on the system and it will work. This is set as a default by some manufacturers to ensure that the lap works on backup on a sudden power failure. Please remove the battery, use a multimeter and check the voltage which has to be a minimum ranging from 7 V to 14.3 V and if its anything less than the same, you need to change the battery which will fix this issue. Good Luck
Mar 18, 2010 | Averatec Computers & Internet
Battery meter is low, even though computer is always plugged in
Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
Oct 07, 2009 | Acer Aspire 6920 Notebook PC
My Garmin street pilot C330 was purchased about 2 years ago. Lately, it has begun giving a message, Low battery. I have had to charged it up on my computer 2 times in the last 2 weeks. What is the problem?...
2 years is generally about it for the battery on the C330.
You most likely need a new battery.
Charging it on or off does not matter.
Run it with the back light on a dimmer mode to increase battery life for now.
Sep 06, 2009 | Garmin StreetPilot C330 GPS Receiver
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Magellan Maestro 3250 GPS Logo
182 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
