Question about Konica Minolta DiALTA Di200 Copier
EP3000 error code c0500 will not clear - Konica Minolta DiALTA Di200 Copier
  • Konica Minolta Master
  • 6,161 Answers
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
Posted on Feb 22, 2010
    Problem Solver:
  • 11 Answers
Similar to manolta 2080 reset trouble sw. behind up. r. cover
Posted on Feb 25, 2010
2 Suggested Answers
  • 18 Answers
SOURCE: help
your heat lamp is not turning on, did you change it? generelly some copiers that old may have to disapate charge in the electronics after being worked on. if the copier did not initiate after rebuilding or doing work on the fuser, you may need to actually unplug it from the wall, like a reboot. the electronics are dated 8 to 10 years old. make sure, if it has a power relay or fuse, because of its age , they are good. generally older units will fire back up at off and on. if nothing works, let us kow.
Posted on Dec 08, 2007
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
On display showing problem code 500
Sir,
Sep 06, 2012 | Minolta Office Equipment & Supplies
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Help
Dec 07, 2007 | Konica Minolta DiALTA Di200 Copier
Code C0500
simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
Sep 07, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
357 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
